USB Sensor data hacking
Hi all,
I am new to the forums and I hope I am posting in the right place. I am trying to access the data from a USB sensor I am trying to have the data from the device be displayed in a LCD instead of having the device connected to a pc, which means replace the pc with an Arduino, I have the proper commands and through the pc’s serial console it works fine but when I have the Arduino send the same command nothing happens, I thought it was because the UNO does not work as a usb host so I got a Due but the same result.
This is my code for the UNO:
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int Resetbutton = 13; // the number of the input pin for resetbutton
int buttonstate = 0; // the current state of the resetbutton
int response = 0;
lcd.begin(16, 2);
pinMode(9, OUTPUT);
pinMode(Resetbutton, INPUT);
digitalWrite(8, HIGH); //Pin 8 for reset need to set it HIGH immediately on boot
pinMode(8,OUTPUT);
lcd.setCursor(0,0);
lcd.print(“Starting…”);
if(Serial.available())
digitalWrite(9, HIGH);
Serial.println(“GET”);
lcd.clear();
response = Serial.read();
lcd.setCursor(0,1);
lcd.print(response);
delay(1500);
lcd.setCursor(0,0);
lcd.clear();
lcd.print(“Error No Serial”);
The due uses the same code except that I replace the Serial for SerialUSB, I ended up with the Error no Serial custom message which makes me wonder if the serial is actually being properly opened, the command is sent on a Loop indefinitely to constantly refresh the LCD screen, I tried connecting the UNO to the DUE by having the UNO send the word “TEST” anytime a Serial connection (via usb connection not the TX/RX) is present to test if the problem was with the usb device but still no results, any idea is appreciated. BTW I am using the native usb port on the due.
