This is my first layout with USB, so I'm not quite sure if this would work... The thing I worry about most is the different power source of USB and the logic. But this is intended to be a board with an RGB LED Matrix, so I'm not able to take all the current over USB if I don't want to fry the port.
Could someone with more experience have a short look over it and tell me if it's ok?
What I'm worrying about most is what will happen when only the USB-Plug is connected and no external power source. Will the controller pass VBUS to the 5V-Pins? This would obviously blow the USB Controller from the computer so I don't hope so.
But since I'm unexperienced with the USB Controllers, I'm a litte bit worrying about this.
And I'm sure one of the gurus here has done such a schematic before...
Thanks!
UCAP is connected to a 1uF-cap.
I actually got the power circuit from the datasheet but it seems I overread that VBUS is just monitoring.
Do I really have to connect AVCC if I don't use ADC?
And what exactly speaks against making an own board with a 4€ MCU instead of putting a breakout board for over 15€ on this board? Getting the PCB made is expensive enough for me...
Yes.
2.2.17: AVCC is the supply voltage pin (input) for all the A/D Converter channels. If the ADC is not used, it should be externally connected to VCC. If the ADC is used, it should be connected to VCC through a low-pass filter.
(otherwise, you have exactly the sort of problem you were worried about with Vusb. Power would "leak" into the A-D circuitry from the digital side through unknown paths, possibly causing all sorts of undesirable behavior.) (also, it's impossible to tell whether AVCC powers "only" the ADC, or whether there is also "other" low-noise circuitry powered from those pins.)
