USBASP correct schematic Very confused here
john1993:
Docedison:
The first is a bad copy... It 'should' work but I'd not use it W/O the diodes.. It's very likely to be 'intermittent' when the diodes that are missing aren't doing their job.
Designing electronics equipment isn't about how many parts you can throw into a circuit. It's about understanding how it is supposed to work and how it must interface with 'other' stuff. Arbitrarily chopping parts out because you don't Think... that they are required would Indicate that you know more than the original designer... were that truly the case...
YOU WOULDN'T BE ASKING WHAT AND WHY HERE... IMO
Doc
i dont have a doctorate (yet), only ee. but one of the first things ive learned is to design according to how things ACTUALLY work and not how they SHOULD or are SUPPOSED to work. i dont mean throwing something together and if it works ship it. but there are usually reasons for paticular components.
checking some app notes for northbridge chips i found the zeners ARE requred. not so much for protecting from chassis grounds or test equipment though but "ringing" and in this case clamping 5v signals from the mega8. since its running directly off the usb vcc there is potential to violate max Vih for the motherboard device. this can result in shutdown which i think is the reason my simplified version failed but the ebay unit works w/o diodes. the ebay mega8 is powered off a 3.3v ldo so didnt trigger an exception.
to test this i went back and altered my kluge to run off 3.3v. guess what... it worked. there are other reasons for the zeners and 68ohm involving slew rates and setup times but my circuit was close enough for usb1.0 operation.
people are of course free to add as many caps, resistors, diodes, or whatever. but personally i choose do so for a reason, not because i think they are SUPPOSED TO or SHOULD be there. ymmv.
What college did you get your EE degree from?
why do you ask? any of my statements not sitting right with you? if so let me know as i enjoy nothing more than setting straight those who think they know more than they actually do. i can usually go into much more detail and happy for the chance to do so.
anyway, no personal info. the LAST thing i need is having some of these internet characters flollowing me home.
john1993:
That is what I figured. You don't have an EE degree. It is obvious.
The Arduino forums are all about learning and helping one another. Let's try not to bash each other.
It's about having fun with tinkering. Arduino is for the everyday layperson not only engineers.
true. few months ago i was not an engineer myself but now this and similar forums helped me achieve my goal. i am quite grateful for that but must admit to getting carried away once in a while. must remember not everyone has the same level of expertise but everyone can enjoy the arduino experience.
So... JUST BECAUSE you think YOU ARE AN ENGINEER...
Docedison:
maybe... but i certainly dont think you are a "doc". sorry.. couldnt resist. :slight_smile:
