USBHostMBed5 FileRead.ino Fails with Crash
I received my GIGA R1 this week and was going through the USBHostMBed5 USBMSD examples. DirLIst and FileWrite examples worked fine but FileRead.ino crashes the GIGA with red light flashing. I narrowed it down to the fgets() call. If I commented that out the sketch would finish without a crash. I tried fread() and got thee same results as fgets().
Starting USB File Read example...
Mounting USB device...
read done Open file..
File content:
That is as far as it gets. I am using USBHostMbed5 version 3.1. I have tried this with Ubuntu 22.04 and Windows 11 and got the same results. I actually went through all of the versions of USBHostMbed5 and the results were the same. The sketch crashed the GIGA.
The sketch I was using:
  Portenta - FileWrite
  The sketch shows how to mount an usb storage device and how to
  write a file, eventually overwriting the original content.
  The circuit:
   - Portenta H7
  This example code is in the public domain.
#include <Arduino_USBHostMbed5.h>
#include <DigitalOut.h>
#include <FATFileSystem.h>
USBHostMSD msd;
mbed::FATFileSystem usb("usb");
// mbed::DigitalOut pin5(PC_6, 0);
mbed::DigitalOut otg(PB_8, 1);
  while (!Serial);
  while (!msd.connect()) {
  Serial.println("Mounting USB device...");
  int err =  usb.mount(&msd);
  if (err) {
    Serial.print("Error mounting USB device ");
    Serial.println(err);
    while (1);
  Serial.print("read done ");
  mbed::fs_file_t file;
  struct dirent *ent;
  int dirIndex = 0;
  int res = 0;
  Serial.println("Open /usb/numbers.txt");
  FILE *f = fopen("/usb/numbers.txt", "w+");
  for (int i = 0; i < 10; i++) {
    Serial.print("Writing numbers (");
    Serial.print(i);
    Serial.println("/10)");
    fflush(stdout);
    err = fprintf(f, "%d\n", i);
    if (err < 0) {
      Serial.println("Fail :(");
      error("error: %s (%d)\n", strerror(errno), -errno);
  Serial.println("File closing");
  fflush(stdout);
  err = fclose(f);
  if (err < 0) {
    Serial.print("fclose error:");
    Serial.print(strerror(errno));
    Serial.print(" (");
    Serial.print(-errno);
    Serial.print(")");
    Serial.println("File closed");
    // handle disconnection and reconnection
    if (!msd.connected()) {
        msd.connect();
I have gone through all of posts in the GIGA hardware posts along with several other searches including:
GIGA R1 USB Mass Storage examples : has anyone managed to run an example project ?
HardwareGIGA R1
Any Ideas?
Thanks
Edit: Tried both Arduino 1.8.19 and 2.2.1...
Sorry, I have not tried running the File system stuff in a while.
Currently playing with other devices and the USBHostMbed5 stuff.
And have had some better luck with first make sure you are at least up to
USBHostMBed5 0.3.1 which hopefully fixed most of the crashes on callbacks.
I am running on my own fork/branch of it as I mentioned in thread about hid objects...
Sorry I know not much help
Hi @KurtE - You were very much helpful along with the others. At first I wasn't really sure were to start but Just followed through the other thread and had both DirList and FileWrite working. I am using version 3.1. I have rebuilt Arduino Mbed-os wiith the debug info turned on. That's where I'll start playing with this. I still am a little familiar with Mbed-os from playing with it on the other forum. Just need to bone up using some sort of debugger for now, probably will use gdb with serial.
Thanks for replying :grinning:
Take a look at https://docs.arduino.cc/tutorials/giga-r1-wifi/giga-usb#usb-host-keyboard, if you add all the 3 libraries listed and run the example sketches, none will crash your Gigi board.
Thanks for the reply @Dozie - Tried the FileRead.ino sketch from that post and got the same results. Red lights and a crash. Again, it's crashing with:
fgets(buf, 256, f)
if i comment out:
  //while (fgets(buf, 256, f) != NULL) {
    //Serial.print(buf);
It does not fail. I don't think it has anything to do with the USBHostMbed5 library at all. It has something to do with the Posix layer fgets, fgetc, fscanf etc...
I have been trying to find out where in the Mbed os library these are implemented. So far I cannot find it. Again this is happening with Ubuntu 22.04 and Windows 11. I am wondering if it has something to do with the version of arm-none-eabi-gcc I have. This only affects the FileRead sketch not FileWrite or DirList sketches. I have tried several USB sticks all formatted to Fat32 without succes.
Any other ideas are very much appreciated :slightly_smiling_face:
Thanks
If you board crashed, try the steps below before testing these examples again.
  1. Add the Arduino Mbed OS Giga Boards (newest version: 4.0.8) to Arduino IDE(2.2.1) using the Boards Manager.|
  2. Burn the bootloader on GIGA R1 WiFi| https://support.arduino.cc/hc/en-us/articles/7991505977116-Burn-the-bootloader-on-GIGA-R1-WiFi
  3. Update Wi-Fi firmware on GIGA R1 WiFi| https://support.arduino.cc/hc/en-us/articles/7991505977884-Update-Wi-Fi-firmware-on-GIGA-R1-WiFi
@Dozie - Before I go any further with updating the bootloader firmware I see a discrepancy.
The instructions in the docs show:
~/.arduino15/packages/arduino/tools/dfu-util/0.11.0-arduino5/dfu-util
My path shows:
~/.arduino15/packages/arduino/tools/dfu-util/0.10.0-arduino1/dfu-util
I deleted Arduino IDE 2.2.1 and .arduino15 then reinstalled the IDE. Went to the boards manager and install version 4.0.8 and reinstalled the latest USBHostMbed5 library 3.1.
It is still showing:
I figured I had better check with you before I updated then bootloader to make sure there is not a problem.
Edit: Went ahead and performed the updates. Same results, crashes at fgets() function...
Hi @wwatson
Just tried a slightly modified version of your sketch, main difference is how I enabled USB host adapter and of course I am using @KurtE version of the MBedos5. But its worth giving it a try with version 3.1 of the lib.
There is note in one of the other examples about the digitalout:
// If you are using a Portenta Machine Control uncomment the following line
mbed::DigitalOut otg(PB_14, 0);
  The circuit:
   - Portenta H7
USBHostMSD msd;
  while (!Serial);
  // Enable the USBHost
  pinMode(PA_15, OUTPUT);
  digitalWrite(PA_15, HIGH);
  delay(100);
  if (err) {
    while (1);
  struct dirent *ent;
  int dirIndex = 0;
  int res = 0;
    Serial.print(i);
    fflush(stdout);
    if (err < 0) {
  fflush(stdout);
  err = fclose(f);
  if (err < 0) {
    Serial.print(" (");
    Serial.print(")");
        msd.connect();
read done Open /usb/numbers.txt
Writing numbers (0/10)
Writing numbers (1/10)
Writing numbers (2/10)
Writing numbers (3/10)
Writing numbers (4/10)
Writing numbers (5/10)
Writing numbers (6/10)
Writing numbers (7/10)
Writing numbers (8/10)
Writing numbers (9/10)
File closing
fclose error:I/O error (-5)
It created the file but not sure why getting the file close error.
Hi @Merlin513 - I just realized that the sketch I posted in #1 was the FileWrite sketch. My mistake :blush:
It is the FileRead sketch that is crashing the GIGA. Here is the sketch:
  Portenta - FileRead
  read from an existing file.
  to use this sketch create a .txt file named Arduino.txt,
  in your storage device and write some content inside.
  The circuit:
   - Portenta H7
USBHostMSD msd;
  while (!Serial);
  delay(2500);
  Serial.println("Starting USB File Read example...");
  // if you are using a Max Carrier uncomment the following line
  //start_hub();
  if (err) {
    while (1);
  struct dirent *ent;
  int dirIndex = 0;
  int res = 0;
  Serial.println("Open file..");
  FILE *f = fopen("/usb/Arduino.txt", "r+");
  char buf[256];
  Serial.println("File content:");
  char *test;
  while ((test = fgets(buf, 256, f)) != NULL) {
    Serial.print(buf);
  fflush(stdout);
  err = fclose(f);
  if (err < 0) {
    Serial.print(" (");
    Serial.print(")");
        msd.connect();
It fails with the call to fgets():
    Serial.print(buf);
It's strange that you are getting an error with the FileWrite.ino sketch. I am not seeing that error:
File closing
File closed
Can you try the FileRead.ino sketch above?
Thanks
Ok I reverted to 3.1 and reran the write sketch and it worked without any errors.
As for the read sketch I am using:
  Portenta - FileRead
  The circuit:
   - Portenta H7
USBHostMSD msd;
  while (!Serial);
    pinMode(PA_15, OUTPUT); //enable the USB-A port
  delay(2500);
  //start_hub();
  if (err) {
    while (1);
  struct dirent *ent;
  int dirIndex = 0;
  int res = 0;
  char buf[256];
  char *test;
    Serial.print(buf);
  fflush(stdout);
  err = fclose(f);
  if (err < 0) {
    Serial.print(" (");
    Serial.print(")");
        msd.connect();
and yep sure enough I got red lights of doom!!!!!! So its not you.
Sorry head is on other stuff...
But maybe try: change 256 to 64 and see if anything changes...
Probably not, but goes from multiple packets to one...
@wwatson - @KurtE
Well think I found the primary issue. With the Write sketch it creates a file named numbers.txt but the read sketch is looking for Arduino.txt so big crash!
If you use the following write sketch:
  The circuit:
   - Portenta H7
USBHostMSD msd;
  while (!Serial);
    delay(100);
  if (err) {
    while (1);
  struct dirent *ent;
  int dirIndex = 0;
  int res = 0;
    Serial.print(i);
    fflush(stdout);
    if (err < 0) {
  fflush(stdout);
  err = fclose(f);
  if (err < 0) {
    Serial.print(" (");
    Serial.print(")");
and read sketch
  Portenta - FileRead
  The circuit:
   - Portenta H7
USBHostMSD msd;
  while (!Serial);
  delay(2500);
  //start_hub();
  if (err) {
    while (1);
  struct dirent *ent;
  int dirIndex = 0;
  int res = 0;
  FILE *f = fopen("/usb/numbers.txt", "r+");
  char buf[256];
  while ((fgets(buf, 256, f)) != NULL) {
    Serial.print(buf);
  fflush(stdout);
  err = fclose(f);
  if (err < 0) {
    Serial.print(" (");
    Serial.print(")");
it works
File content:
0
1
2
3
4
5
6
7
8
9
File closing
File closed
Nice find :grinning: I did not notice that. Same results:
File content:
0
1
2
3
4
5
6
7
8
9
File closing
File closed
That was kinda obvious but I completely missed it. The next question if a file is not found will it return an error. Will check it out...
Thanks
Yeah but it took me a while before the :bulb:to come on before I realized it.
@Merlin513 @KurtE - I modified the FileRead sketch to check for a non-existent file. It does set an error in the errno variable when checked.
Here is the modified sketch. I removed the 'n' in /usb/numbers.txt:
  Portenta - FileRead
  The circuit:
   - Portenta H7
#include <error.h>
USBHostMSD msd;
  while (!Serial);
  delay(2500);
  //start_hub();
  if (err) {
    while (1);
  struct dirent *ent;
  int dirIndex = 0;
  int res = 0;
  FILE *f = fopen("/usb/umbers.txt", "r+");
  // Check for error and report it.
  if(f == NULL) {
	Serial.print("Faied: error code: ");
    Serial.println(errno,DEC);
    Serial.println(strerror(errno));
    Serial.println("Halting...");
    while(1);
  char buf[256];
    Serial.print(buf);
  fflush(stdout);
  err = fclose(f);
  if (err < 0) {
    Serial.print(" (");
    Serial.print(")");
        msd.connect();
It reports:
Faied: error code: 2
No such file or directory
Halting...
Now on to other things :grinning:
@KurtE - @wwatson
unfortunately with @KurtE's current working branch with a bunch of changes when you run the write sketch you get the file close error:
File closing
and file is empty :frowning: which is a different issue.
I have not tried @KurtE's library yet. Need to try it out...
@Merlin513 - I tried @KurtE's library and did not get the fclose() error :confused:
File closing
File closed
Not sure...
Interesting I just tried again with 2 different USB drives and both gave me the same error on close. This is the branch I am using: KurtE/Arduino_USBHostMbed5 at usb_host_fixes_lowspeed (github.com) unless I missed something.
@Merlin513 - I switched to that branch and got the same results as you. I am not familiar yet with this library but I know it is still WIP...
