Here is the UsbKeyboard.h library file I am using
* Based on Obdev's AVRUSB code and under the same license.
* TODO: Make a proper file header. :-)
#ifndef __UsbKeyboard_h__
#define __UsbKeyboard_h__
#include <avr/pgmspace.h>
#include <avr/interrupt.h>
#include <string.h>
#include "usbdrv.h"
// TODO: Work around Arduino 12 issues better.
//#include <WConstants.h>
//#undef int()
typedef uint8_t byte;
#define BUFFER_SIZE 4 // Minimum of 2: 1 for modifiers + 1 for keystroke
static uchar idleRate; // in 4 ms units
/* We use a simplifed keyboard report descriptor which does not support the
* boot protocol. We don't allow setting status LEDs and but we do allow
* simultaneous key presses.
* The report descriptor has been created with usb.org's "HID Descriptor Tool"
* which can be downloaded from http://www.usb.org/developers/hidpage/.
* Redundant entries (such as LOGICAL_MINIMUM and USAGE_PAGE) have been omitted
* for the second INPUT item.
PROGMEM char usbHidReportDescriptor[35] = { /* USB report descriptor */
0x05, 0x01, // USAGE_PAGE (Generic Desktop)
0x09, 0x06, // USAGE (Keyboard)
0xa1, 0x01, // COLLECTION (Application)
0x05, 0x07, // USAGE_PAGE (Keyboard)
0x19, 0xe0, // USAGE_MINIMUM (Keyboard LeftControl)
0x29, 0xe7, // USAGE_MAXIMUM (Keyboard Right GUI)
0x15, 0x00, // LOGICAL_MINIMUM (0)
0x25, 0x01, // LOGICAL_MAXIMUM (1)
0x75, 0x01, // REPORT_SIZE (1)
0x95, 0x08, // REPORT_COUNT (8)
0x81, 0x02, // INPUT (Data,Var,Abs)
0x95, BUFFER_SIZE-1, // REPORT_COUNT (simultaneous keystrokes)
0x75, 0x08, // REPORT_SIZE (8)
0x25, 0x65, // LOGICAL_MAXIMUM (101)
0x19, 0x00, // USAGE_MINIMUM (Reserved (no event indicated))
0x29, 0x65, // USAGE_MAXIMUM (Keyboard Application)
0x81, 0x00, // INPUT (Data,Ary,Abs)
0xc0 // END_COLLECTION
/* Keyboard usage values, see usb.org's HID-usage-tables document, chapter
* 10 Keyboard/Keypad Page for more codes.
#define MOD_CONTROL_LEFT (1<<0)
#define MOD_SHIFT_LEFT (1<<1)
#define MOD_ALT_LEFT (1<<2)
#define MOD_GUI_LEFT (1<<3)
#define MOD_CONTROL_RIGHT (1<<4)
#define MOD_SHIFT_RIGHT (1<<5)
#define MOD_ALT_RIGHT (1<<6)
#define MOD_GUI_RIGHT (1<<7)
#define KEY_A 4
#define KEY_B 5
#define KEY_C 6
#define KEY_D 7
#define KEY_E 8
#define KEY_F 9
#define KEY_G 10
#define KEY_H 11
#define KEY_I 12
#define KEY_J 13
#define KEY_K 14
#define KEY_L 15
#define KEY_M 16
#define KEY_N 17
#define KEY_O 18
#define KEY_P 19
#define KEY_Q 20
#define KEY_R 21
#define KEY_S 22
#define KEY_T 23
#define KEY_U 24
#define KEY_V 25
#define KEY_W 26
#define KEY_X 27
#define KEY_Y 28
#define KEY_Z 29
#define KEY_1 30
#define KEY_2 31
#define KEY_3 32
#define KEY_4 33
#define KEY_5 34
#define KEY_6 35
#define KEY_7 36
#define KEY_8 37
#define KEY_9 38
#define KEY_0 39
#define KEY_ENTER 40
#define KEY_SPACE 44
#define KEY_F1 58
#define KEY_F2 59
#define KEY_F3 60
#define KEY_F4 61
#define KEY_F5 62
#define KEY_F6 63
#define KEY_F7 64
#define KEY_F8 65
#define KEY_F9 66
#define KEY_F10 67
#define KEY_F11 68
#define KEY_F12 69
#define KEY_ARROW_LEFT 0x50
class UsbKeyboardDevice {
public:
UsbKeyboardDevice () {
PORTD = 0; // TODO: Only for USB pins?
DDRD |= ~USBMASK;
cli();
usbDeviceDisconnect();
usbDeviceConnect();
usbInit();
sei();
// TODO: Remove the next two lines once we fix
// missing first keystroke bug properly.
memset(reportBuffer, 0, sizeof(reportBuffer));
usbSetInterrupt(reportBuffer, sizeof(reportBuffer));
void update() {
usbPoll();
void sendKeyStroke(byte keyStroke) {
sendKeyStroke(keyStroke, 0);
void sendKeyStroke(byte keyStroke, byte modifiers) {
while (!usbInterruptIsReady()) {
// Note: We wait until we can send keystroke
// so we know the previous keystroke was
// sent.
reportBuffer[0] = modifiers;
reportBuffer[1] = keyStroke;
// sent.
// This stops endlessly repeating keystrokes:
//private: TODO: Make friend?
uchar reportBuffer[4]; // buffer for HID reports [ 1 modifier byte + (len-1) key strokes]
UsbKeyboardDevice UsbKeyboard = UsbKeyboardDevice();
#ifdef __cplusplus
extern "C"{
#endif
// USB_PUBLIC uchar usbFunctionSetup
uchar usbFunctionSetup(uchar data[8])
usbRequest_t *rq = (usbRequest_t *)((void *)data);
usbMsgPtr = UsbKeyboard.reportBuffer; //
if((rq->bmRequestType & USBRQ_TYPE_MASK) == USBRQ_TYPE_CLASS){
/* class request type */
if(rq->bRequest == USBRQ_HID_GET_REPORT){
/* wValue: ReportType (highbyte), ReportID (lowbyte) */
/* we only have one report type, so don't look at wValue */
// TODO: Ensure it's okay not to return anything here?
return 0;
}else if(rq->bRequest == USBRQ_HID_GET_IDLE){
// usbMsgPtr = &idleRate;
// return 1;
return 0;
}else if(rq->bRequest == USBRQ_HID_SET_IDLE){
idleRate = rq->wValue.bytes[1];
}else{
/* no vendor specific requests implemented */
return 0;
#ifdef __cplusplus
} // extern "C"
#endif
#endif // __UsbKeyboard_h__
