"usbserial" vanished from the Serial Port submenu
I've been using the Arduino Duemilanove pretty solidly for about a day and a half now, and am nearing the end of my particular experiment, when suddenly, Arduino (the programming environ) locked up, and after force quitting, rebooting, re-installing the latest usbserial drivers i could find (2.2.10), I still only have bluetooth drivers in the serial menu.
What happened? Is there a log I can look at? Some sort of weird reset scenario?
I'm on a Macbook Pro with Leopard.
The USB ports are still functional, according to the iPhone.
Funny, just today I had a solder bridge resulting in a power short and saw the same behavior. Once I removed the offending shield, the Arduino was just fine.
Check for a power overload or maybe a short.
-j
Really? And that removed those /dev files from the host OS? Is the software just sort of "giving up"?
ANd, yeah, i was working on a protoshield, but even before I plug back in the USB, there is no /dev/usb* whatever.
Hmf.
I'm brewing tomorrow, and hoped I could finish this dumb bubble counter before then. Beer comes first, though. :slight_smile:
The device special files (/dev/tty.usbserial-12345678) are dynamic, and only exist when the device is attached.
-j
Well, that 'splains that.
I have a larger issue then. :frowning:
Without any shield, the Arduino apparently no longer registers.
Advice?
Power cycle everything, all at the same time. Watch for any powered hubs, etc. If that doesn't work, change to a different USB port.
If it doesn't work after that, it's beginning to sound like a dead arduino...
Which arduino? The Diecimilla and newer models have a polyfuse, which may offer some protection. That fuse is self-resetting, but I suppose it is possible to stress it past the point it can recover.
Maybe someone else has ideas.
-j
