Greetings,
Apologies in advance if this is an FAQ (if so, where?)
I recently upgraded to Arduino 1.6.6 on a Win7 64bit PC. I’m unable to program the Blinky example sketch to an Arduino UNO R3 board using the AVR Pocket Programmer (from Sparkfun Electronics)
The drivers are the latest:
Driver provider libusb-win32
Driver Date: 1/15/2013
Driver Version: 1.2.6.0
Digital Signer: Adafruit Industries
I discovered that I can program the blinky hex file to the same UNO board using AVRDude from a CMD window.
Avrdude –c usbtiny –patmega328p –U flash:w:Blinky_01.ino.hex
I think the hardware is correct, should I expect to program this hardware directly from the Arduino IDE? ( Tools > Board = Arduino/Genuino UNO and Tools > Programmer = USBtinyISP Note: “Port” option is grayed out)
I get the following error message from the Arduino IDE
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is “C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf”
Using Port : COM10
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can’t open device “\.\COM10”: The system cannot find the file specified.
avrdude done. Thank you.
I’m returning to this project after a long absence, what did I forget to do…?
Thanks In Advance!
