Use 2 IR Receiver
Hi, i try to use 2 ir recevier in the same time with arduino, and i try to se from what ir is the signal coming.
my ir are TSOPxxxx, but the problem is in the program, i don’t know how to use 2 ir recevier on the same arduino.
i try to use JVCPanasonicSendDemo for transmitter. i try to make something like this but dont working well:
#include <IRremote.h>
int RECV_R = 12;
int RECV_L = 11;
int on = 0;
IRrecv irrecvR(RECV_R);
IRrecv irrecvL(RECV_L);
decode_results results;
  irrecvR.enableIRIn(); // Start the receiver
  irrecvL.enableIRIn(); // Start the receiver
  pinMode(A0, OUTPUT);// Start the receiver
  pinMode(A1, OUTPUT);// Start the receiver
  pinMode(A2, OUTPUT);// Start the receiver
  pinMode(A3, OUTPUT);
void dumpL(decode_results *results) {
  int count = results->rawlen;
  if (results->decode_type == UNKNOWN) {
    Serial.print("Unknown encoding: ");
  else if (results->decode_type == PANASONIC) {
    Serial.print("Decoded PANASONIC - Address: ");
    Serial.print(results->panasonicAddress, HEX);
    Serial.print(" Value: ");
    digitalWrite(A0, on);
    digitalWrite(A2, on);
  Serial.print(results->value, HEX);
  Serial.print(" ");
  Serial.print(results->value, DEC);
  Serial.print(" (");
  Serial.print(results->bits, DEC);
  Serial.println(" bits)");
  Serial.print("Raw (");
  Serial.print(count, DEC);
  Serial.print("): ");
  Serial.println("");
void dumpR(decode_results *results) {
    digitalWrite(A1, on);
    digitalWrite(A3, on);
  Serial.print(" ");
  Serial.print(" (");
  Serial.println("");
  digitalWrite(A0, 1023);
  digitalWrite(A1, 1023);
  digitalWrite(A2, 1023);
  digitalWrite(A3, 1023);
  if (irrecvR.decode(&results) && irrecvL.decode(&results)) {
    Serial.println(" TWO ");
    irrecvR.resume();
    irrecvL.resume();
    else if (irrecvL.decode(&results)) {
    Serial.println(" L ");
    dumpL(&results);
    irrecvL.resume();  // Receive the next value
  else if (irrecvR.decode(&results)) {
    Serial.println(" R ");
    dumpR(&results); // Receive the next value
    irrecvR.resume();
How is the solution??
It is most likely because the library for the IR uses the same timer. I seem to recall reading something about this.
Do your research!
Maybe something like this?
#define DECODE_PANASONIC 1
int RECV_R = 12;
int RECV_L = 11;
int on = LOW;
void dump(decode_results *results, int Pin1, int Pin2) {
    digitalWrite(Pin1, on);
    digitalWrite(Pin2, on);
  Serial.print(" ");
  Serial.print(" (");
  Serial.println("");
  digitalWrite(A0, HIGH);
  digitalWrite(A1, HIGH);
  digitalWrite(A2, HIGH);
  digitalWrite(A3, HIGH);
    Serial.println("\n\n L ");
    dump(&results, A0, A2);
    Serial.println("\n\n R ");
    dump(&results, A1, A3);
    irrecvR.resume(); // Receive the next value
but the only signal received by pin 11
I just checked the IRremote library sources. They only support one input at a time. You may need to look for a different library from someone who has solved this problem before.
Ok thanks for your answer mr johnwasser (y)
