Hello
I'm not very well known about pwm
but i assume pwm is controlling voltage amount 0~5V by 0~255
then could I turn on the LED which peak at 3.2V
by controlling pwm?
If I use digital output i should use resistor....right?
please help me
Hello
by controlling pwm?
please help me
No, that is not what happens. The function name "analogWrite" is misleading. In reality it is a pulse width modulated (pwm) 5V signal. So you can use your led with an appropriate value series resistor calculated for a 5V source.
PaulRB:
thanks for your advice!!
Read this all about PWM it will help you understand what is going on:-
http://www.thebox.myzen.co.uk/Tutorial/PWM.html
You always need a resistor, or some other current limiting circuit with an LED, you can not just use an LED without.
Here is why:- http://www.thebox.myzen.co.uk/Tutorial/LEDs.html
