Hi all,
I need some help with my project. I found the thread with 4 Hx711 and also the code from here
https://github.com/compugician/HX711-multi
I managed to read cels using only 4 HX711 but when i try with 6 i get only 0 on the output for all 6 channels.
this is my code:
#include "HX711-multi.h"
// Pins to the load cell amp
#define CLK 13 // clock pin to the load cell amp
#define DOUT1 A0 // data pin to the first lca
#define DOUT2 A1 // data pin to the second lca
#define DOUT3 A2 // data pin to the third lca
#define DOUT4 A3 // data pin to the third lca
#define DOUT5 A6 // data pin to the third lca
#define DOUT6 A7 // data pin to the third lca
#define BOOT_MESSAGE "MIT_ML_SCALE V0.8"
#define TARE_TIMEOUT_SECONDS 4
byte DOUTS[6] = {DOUT1, DOUT2, DOUT3, DOUT4, DOUT5, DOUT6};
#define CHANNEL_COUNT sizeof(DOUTS)/sizeof(byte)
long int results[CHANNEL_COUNT];
HX711MULTI scales(CHANNEL_COUNT, DOUTS, CLK);
Serial.println(BOOT_MESSAGE);
Serial.flush();
pinMode(11,OUTPUT);
tare();
void tare() {
bool tareSuccessful = false;
unsigned long tareStartTime = millis();
while (!tareSuccessful && millis()<(tareStartTime+TARE_TIMEOUT_SECONDS*1000)) {
tareSuccessful = scales.tare(20,10000); //reject 'tare' if still ringing
void sendRawData() {
scales.read(results);
for (int i=0; i<scales.get_count(); ++i) {;
Serial.print( -results[i]);
Serial.print( (i!=scales.get_count()-1)?"\t":"\n");
delay(10);
sendRawData(); //this is for sending raw data, for where everything else is done in processing
//on serial data (any data) re-tare
if (Serial.available()>0) {
while (Serial.available()) {
Serial.read();
tare();
Anyone has any ideea what i am doing wrong?
Thanks
