Use a display with CE, CLK and DI (SPI)
Hi everyone, I'm trying to use a display from a BMW, which works perfectly.
For this display I have 5 pins available: VDD, GND, CE, CLK and DD, so I will have to use the SPI protocol.
I've been trying for three weeks now to make it work, but I'm going crazy and haven't seen any improvement yet.
I'm trying to do a very simple character fill and a total cleaning of the display, but I can't show a single character.
Attached I leave you the datasheet of the chip that manages the display and the code I wrote.
If in some way you can help me, I will always love you.
I'm not really understanding why you don't show anything.
LC75824.pdf (416.5 KB)
// UNO
// pin8 PB0
// pin9 PB1
// pin10 PB2
#define CLK 8
#define CE 9
#define DATA 10
// address[8] data[52] space[2] settings[8] dd[2]         address[8] data[52] space[10] dd[2]          address[8] data[52] space[10] dd[2]            address[8] data[48] space[14] dd[2]
byte data[288] = {1,0,0,0,0,0,1,0, 1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1, 0,0, 0,1,0,0,0,0,1,0, 0,0,     1,0,0,0,0,0,1,0, 1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1, 0,0,0,0,0,0,0,0,0,0, 0,1,       1,0,0,0,0,0,1,0, 1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1, 0,0,0,0,0,0,0,0,0,0, 1,0,       1,0,0,0,0,0,1,0, 1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1, 0,0,0,0,0,0,0,0,0,0,0,0,0,0, 1,1};
// array filled   1 0 0 0 0 0 1 0  1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1  0 0  0 1 0 0 0 0 1 0  0 0      1 0 0 0 0 0 1 0  1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1  0 0 0 0 0 0 0 0 0 0  0 1        1 0 0 0 0 0 1 0  1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1  0 0 0 0 0 0 0 0 0 0  1 0        1 0 0 0 0 0 1 0  1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1  0 0 0 0 0 0 0 0 0 0 0 0 0 0  1 1
// array clean    1 0 0 0 0 0 1 0  0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0  0 0  0 1 0 0 0 0 1 0  0 0      1 0 0 0 0 0 1 0  0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0  0 0 0 0 0 0 0 0 0 0  0 1        1 0 0 0 0 0 1 0  0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0  0 0 0 0 0 0 0 0 0 0  1 0        1 0 0 0 0 0 1 0  0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0  0 0 0 0 0 0 0 0 0 0 0 0 0 0  1 1
int minus=1;
int tick;
  pinMode(CLK, OUTPUT);
  pinMode(CE, OUTPUT);
  pinMode(DATA, OUTPUT);
  digitalWrite(CLK, 0);
  digitalWrite(CE, 0);
  digitalWrite(DATA, 0);
  delay(30);
  //ClearDisplay();
  ClearDisplay();
  showArray();
  delay(50);
  FillDisplay();
  showArray();
  delay(50);
  //ClearDisplayOne();
  delay(50);
  //Print("");
void showArray(){
  for(int j=0; j<288; j++){
    Serial.print(data[j]);
  Serial.println("");
void PrintData(){
  tick = 1;
  minus=1;
  comehere:
  /*if(tick == 10 || tick == 83 || tick == 156 || tick == 229){
    PORTB = PORTB | B00000010; // CE UP
    delayMicroseconds(1);
  if(tick == 74 || tick == 147 || tick == 220){
        PORTB = PORTB & B11111110; // CLK DOWN
    //PORTB = PORTB & B11111101; // CE DOWN
  if(tick==9 || tick==82 || tick==155 || tick==228){
    tick++;
    goto comehere;
  if(tick==10){
      minus=2;
  if(tick==83){
    minus=3;
  if(tick==155){
      minus=4;
  if(tick==229){
    minus=5;
  if(data[tick-minus] == 0){
    PORTB = PORTB & B11111011; // DATA DOWN
          PORTB = PORTB | B00000001; // CLK UP
  else{
    PORTB = PORTB | B00000100; // DATA UP
  if(tick < 292){
    tick++;
    goto comehere;
  if(data[tick-1] == 0){
  else{
  delayMicroseconds(10);
  if(tick == 9 || tick == 81 || tick == 153 || tick == 225){
  if(tick == 73 || tick == 145 || tick == 217){
  if(tick < 283){
    tick++;
    goto comehere;
  delay(10);
void FillDisplay(){
  for(int j = 8; j <= 59; j++){
    data[j] = 1;
    //PrintData();
  for(int j = 80; j <= 131; j++){
    data[j] = 1;
    //PrintData();
  for(int j = 152; j <= 203; j++){
    data[j] = 1;
    //PrintData();
  for(int j = 224; j <= 271; j++){
    data[j] = 1;
    //PrintData();
  PrintData();
void FillDisplayOne(){
    data[j] = 1;
    PrintData();
    data[j] = 1;
    PrintData();
    data[j] = 1;
    PrintData();
    data[j] = 1;
    PrintData();
  //PrintData();
void ClearDisplay(){
    data[j] = 0;
    //PrintData();
    data[j] = 0;
    //PrintData();
    data[j] = 0;
    //PrintData();
    data[j] = 0;
    //PrintData();
  PrintData();
void ClearDisplayOne(){
    data[j] = 0;
    PrintData();
    data[j] = 0;
    PrintData();
    data[j] = 0;
    PrintData();
    data[j] = 0;
    PrintData();
  //PrintData();
