Use a PIR sensor in Processing to launch a webcam and audio
I have correct the code of how to use a PIR Sensor in Arduino, but I do not know how to launch a Processing sketch that opens the webcam and a soud.
Please, ¿Can you help me?.
I don't know how you could launch a Processing program with the Arduino. You haven't said what operating system that you are using, anyway. That information is probably important. If the Processing program is already running, it would be pretty easy to send a serial signal to Processing to do what you want.
I have an issue with the port, Where I can find the info of the port?, is not a COM 6.
