Use a TCP connection to send a WOL packet
Hello
I working on the code below but i can't get it to send the wol packet. any one who help me out?
The purpose for the code is that I connect to arduino with a tcp connection and then I send a command to it fx. "target1" and then i generates a Wol packet based on the mac address and send to the target ip and close the tcp connection. but i think the code breaks before it sends the wol packet.
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
EthernetUDP Udp;
// Enter a MAC address, IP address and Portnumber for your Server below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress serverIP(xxx,xxx,x,xx);
byte gateway[] = { xxx, xxx, xx, xx }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(xxxx); //server port
// TARGET 1
byte targetIp1[] = { xxx, xxx, x, x };
int targetPort1 = x;
byte wolMac1[] = { 0xXX,0xXX,0xXX,0xXX,0xXX,0xXX }; // The target PC Mac Address
// TARGET 2
byte targetIp2[] = { xxx, xxx, x, xx };
int targetPort2 = x;
byte wolMac2[] = { 0xXX,0xXX,0xXX,0xXX,0xXX,0xXX }; // The target PC Mac Address
// Initialize the Ethernet server library
// with the IP address and port you want to use
 // start the Ethernet connection and the server:
  Ethernet.begin(mac, serverIP, gateway, subnet);
  server.begin();
  if (client) {
    char inBuffer[116];
    int inCount = 0;
    while (client.connected()) {
      while (client.available()) {
        char ch = client.read();
       if(inCount < 31 && ch != '\r' && ch != '\n') {
          inBuffer[inCount] = ch;
          inCount++;
          inBuffer[inCount] = 0;
      byte all[102];
  int i,c1,j=0;
  for(i = 0; i < 6; i++,j++){
    all[j] = 0xFF;
  for(i = 0; i < 16; i++){
    for( c1 = 0; c1 < 6; c1++,j++)
      all[j] = wolMac1[c1];
//if "target1" received it should generate a wol1 packet and send it to target 1
if(strcmp(inBuffer,"target1") == 0){
Udp.beginPacket(targetIp1,targetPort1);
for(i = 0; i < 102; i++);
Udp.write(all[i]);
Udp.endPacket();
client.println("The power is ON");
//if "target2" received it should generate a wol1 packet and send it to target 2
if(strcmp(inBuffer,"target2") == 0) {
Udp.beginPacket(targetIp2,targetPort2);
Udp.write(all[i]);
Udp.endPacket();
client.println("The power is OFF");
      if(inCount > 0) {
        // send response to client here if you wish
        client.println("Closing connection");
        delay(2000);
        client.stop();
Thanks in advance
I suggest you use the "auto-indent" feature. I don't know how you can make anything out of your indenting system.
This, for example, looks wrong:
 Udp.write(all[i]);
The semicolon on the first line means the loop does nothing useful. There is another like it further down.
Worse than doing nothing useful, it causes the first element beyond the end of the array to be written to the UDP connection.
Well, that's not useful. :stuck_out_tongue:
