use analogread as for a switch
I am trying to apply 5v to a piezio buzzer when(if) the voltage going into the analog input drops below 5v, how would I program the arduino to do that?
I will be adding it to this code
This is an example sketch for our optical Fingerprint sensor
Designed specifically to work with the Adafruit BMP085 Breakout
----> http://www.adafruit.com/products/751
These displays use TTL Serial to communicate, 2 pins are required to
interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
Code modified and Project Built By Carrigan Luneke
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
int getFingerprintIDez();
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
Serial.println(“fingertest”);
pinMode(11, OUTPUT); //Red LED
pinMode(12, OUTPUT); //Green LED
pinMode(10, OUTPUT); //Garage Bridge
// set the data rate for the sensor serial port
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println(“Found fingerprint sensor!”);
Serial.println(“Did not find fingerprint sensor :(”);
while (1);
Serial.println(“Waiting for valid finger…”);
void loop() // run over and over again
digitalWrite(11, HIGH); // Red LED ON
digitalWrite(12, LOW); // Green LED OFF
digitalWrite(10, LOW); //Garage opener not Active
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println(“Image taken”);
case FINGERPRINT_NOFINGER:
Serial.println(“No finger detected”);
return p;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println(“Communication error”);
return p;
case FINGERPRINT_IMAGEFAIL:
Serial.println(“Imaging error”);
return p;
default:
Serial.println(“Unknown error”);
return p;
// OK success!
p = finger.image2Tz();
switch (p) {
Serial.println(“Image converted”);
case FINGERPRINT_IMAGEMESS:
Serial.println(“Image too messy”);
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println(“Could not find fingerprint features”);
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
// OK converted!
p = finger.fingerFastSearch();
if (p == FINGERPRINT_OK) {
Serial.println(“Found a print match!”);
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
Serial.println(“Did not find a match”);
return p;
return p;
// found a match!
Serial.print(“Found ID #”); Serial.print(finger.fingerID);
Serial.print(" with confidence of "); Serial.println(finger.confidence);
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
// found a match!
digitalWrite(11, LOW); //Red LED OFF
digitalWrite(12, HIGH); //Green LED ON
digitalWrite(10, HIGH); //Garage Opener Active
delay(1000); //Applies 0v for one second, may be different for each opener
return finger.fingerID;
The input to the analogue pin had better not go above 5V or you may fry your Arduino. What range of voltages do you plan to apply to the pin ? If it is greater than 5V you could use a voltage divider to scale the input into the 0 to 5V range then do an analogRead() and calculate the voltage. You will get a value of 0 for 0V input, 1023 for an input of 5V and all values in between in proportion to the voltage.
You can also use digitalRead() and digitalWrite() on analog pins.
//Wire a switch between GND and Analog 0 (zero)
#define INPUT_SWITCH_PIN A0
//use the builtin LED on pin 13 as an indicator
#define OUTPUT_LED 13
  pinMode(INPUT_SWITCH_PIN, INPUT_PULLUP);
  pinMode(OUTPUT_LED, OUTPUT);
  boolean IsPressed;
  IsPressed = !digitalRead(INPUT_SWITCH_PIN);  //active-low switch, inverted with !
  digitalWrite(OUTPUT_LED, IsPressed);
