I am currently trying to monitor the voltage output from a photodiode with the Arduino due analog input. When I do not add much else to the circuit, the results I get only change for about 50 points of the analog in resolution between modest daylight and close to darkness.
So I figured it would be good to use an OpAmp to give my resolution a boost.
Now I read that the arduino due can only take up to 3,3V and I'm afraid of damaging the board, because the Op Amp might put out much more.
I would greatly appreciate any suggestions how to approach my problem.
If you power the op-amp from 3.3V you can't get more than that out. In fact, you won't quite reach the supply voltage. If you choose that method, look for a low-voltage rail-to-rail op-amp.
Another approach is [u]protection diodes[/u]. (I'm not using photo diodes, but I normally power my op-amp from +/- 12V and I use protection diodes.)
Since photodiodes are current sources they usually use a "special" circuit. So, I suggest you search for "photodiode amplifier". And/or, consider using a phototransistor.
What is not much else?
A photo diode while giving a fast response does not have a large output. You need to use something like a photo resistor for measuring ambient light. Connect it between input and ground and have a pull up to 3V3 approximately equal in value to the resistance of the sensor at the mid light level you want to operate with.
For a good daylight sensor I have used the photo transistor SFH3410.
I don't see in post#0 how the photodiode is used.
Photovoltaic, or photoresistive with a pullup resistor.
An A/D value of 50 is low. Maybe OP has forgotten the resistor.
If not, what is the value of that pullup resistor.
Post a diagram and the code.
Leo..
DVDdoug:
Thank you, I will try that one.
Grumpy_Mike:
Thx for the suggestion, but I mainly want to use it for detecting motion, so I need a fast response. In the end I want to build an array of like 8x8 diodes, but for now I am testing circuits on a single one.
