I want to use Arduino as an axis card to control 3 stepper motors
The three stepper motor must be done interpolation operation(arc interpolation and straight line interpolation)
Arduino can do it?
Thank-you.
Arduino can do it?
Thank-you.
Yes.
...R
PS... If you want a more extensive answer then YOU need to provide a lot more information.
First of all.
Thank you for your reply.
The 3 stepper motors are orientalmotor
I want to use this architecture to do the interpolation operation
e.g.
Draw a circle(this round wire must not be serrated and must be smooth)
Draw a slash(this slash must not be serrated)
Ultimately I want to apply this architecture to a CNC or 3D printer
Originally intended to use three-axis axis card to do the control
But want to try something different so use Arduino
Can you give me some video on the actual situation of multi-axis control using Arduino?
guk86554:
I suspect you will save yourself a lot of trouble if you learn about Gcode and an Arduino program called GRBL
And if you use a drawing program to create your design and a suitable program to convert the drawing to GCode. There is a program called slic3r (note the strange spelling) that converts 3D images into Gcode for 3D printers. If you trick it into thinking your drawing is just 1 layer deep you will get nice Gcode for a simple drawing.
There are also many other programs that will convert drawing files to Gcode.
...R
