## Using this core as an mbed library
You can use this core as a standard mbed library; all APIs are under `arduino` namespace (so they must be called like `arduino::digitalWrite()` )
Does anyone has an example of doing this, especially from command-line using mbed-cli or mbed-tools?
It is easier if you use the Arduino IDE and use the Mbed functions from there. Then you have the full build of Arduino + Mbed.
The Arduino functions using Mbed are pretty straightforward. I assume that they should work as a library for the Mbed build environment, but I have never tried that.
I assume that you can upload Mbed code to the Portenta ?
Yep, Arduino IDE works, and I can use some of the mbed libs from there. However, I thought running mbed by itself would allow me to to: build in Docker for hermetic builds, execute unit tests in CI, simulate the board using FVP or qemu
That is way beyond my programming skills
I replied to your post because I read that note about using the ArduinoCore as standard Mbed library as well.
Offtopic: I have a Raspberry Pi Pico and not a Portentia board. The Raspberry Pi Pico support benefited a lot from the existing Mbed core. I think that the Wokwi simulation of the Raspberry Pi Pico simulates the hardware, regardless how many software layers are on top of it: https://www.youtube.com/watch?v=myNILbIA8qU
