Use button to step through program
Hello all,
It's been a while since my last project, and I'm feeling a bit rusty on my coding. I have some neopixels connected to an arduino, and I want to connect a button to simply cycle through the different colors.
Something like (psudo code):
ColorWipe Red
button press
ColorWipe Green
button press
ColorWipe Blue
button press
Any thoughts on how best to code the button press without using a bunch of nested if statements? Thanks!
You need a variable to keep track of what stage you are at.
It starts at 0 First press increases it to 1 Second press increases it to 2 etc Fourth push sends it back to 0 (perhaps)
Put the code for the different sequences into functions - something like
void greenWipe() {
   if  (btnCount == 1) {
       // whatever makes a green wide
Then loop() would be something like this
   readButton();
   greenWipe();
   redWipe();
   blueWipe();
...R
EDIT: I was using == instead of =. All is working now!
Great! Thanks for the help, I have it working now, all but the reset part. I tried using this:
	if (buttonPushCounter == 7)
		buttonPushCounter == 1;
to reset it after 7 pushes, but it just ignores it and keeps on counting. I tried placing it at several places throughout the code, but same result. Any idea how to loop it back to the beginning? Thanks again for the help!
#define PINA 6    //ws2812 strip a
#define FADESPEED 5     // make this higher to slow down
#define NUMPIX 6  // number of pixels
#define buttonPin 4 // Input for the button
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip_a = Adafruit_NeoPixel(NUMPIX, PINA, NEO_RGB + NEO_KHZ800);
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;
	pinMode(buttonPin, INPUT_PULLUP);
	strip_a.begin();
	strip_a.show();     // Initialize all pixels to 'off'
	colorWipe(255, 255, 255);
	buttonState = digitalRead(buttonPin);  // read the pushbutton input pin:
	if (buttonState != lastButtonState)		// compare the buttonState to its previous state
		// if the state has changed, increment the counter
		if (buttonState == HIGH)
			buttonPushCounter++;
			Serial.println("on");			// if the current state is HIGH then the button	went from off to on:
			Serial.print("number of button pushes:  ");
			Serial.println(buttonPushCounter);
			Serial.println("off");				// if the current state is LOW then the button went from on to off
	lastButtonState = buttonState;	// save the current state as the last state for next time through the loop
	purpleWipe();
	blueWipe();
	whiteWipe();
	redWipe();
	aquaWipe();
	greenWipe();
	reset();
void purpleWipe()
	if  (buttonPushCounter == 1)
		colorWipe(255, 0, 255);  //wipe to purple
void blueWipe()
	if  (buttonPushCounter == 2)
		colorWipe(0, 0, 255);  //wipe to blue
void whiteWipe()
	if (buttonPushCounter == 3)
void redWipe()
	if  (buttonPushCounter == 4)
		colorWipe(255, 0, 0);  //wipe to red
void aquaWipe()
	if  (buttonPushCounter == 5)
		colorWipe(0, 255, 255);  //wipe to aqua
void greenWipe()
	if  (buttonPushCounter == 6)
		colorWipe(0, 255, 0);  //wipe to green
void reset()
void colorWipe(int r, int g, int b)
	for (int x = 0; x < NUMPIX; x++)        //incriment counter
		strip_a.setPixelColor(x, r, g, b);      //turn on pixel
		delay(100);
		strip_a.show();
OK nevermind! I was using == instead of =.
All is well! Thanks again!
int dimmerMode() {
int counter, setMode;
++counter;
switch (counter) {
case 1:
setMode = 1;
case 2:
setMode = 2;
case 3:
setMode = 3;
case 4:
setMode = 4;
counter = 0;
return setMode;
I would use
if (buttonPushCounter >= 7)
That way if it somehow misses 7 it will still reset your counter.
