Use byte instead of int to store pin references ? Memory consumption.
Hello guys (and lads) !
I bought my Uno some days ago and have been playing with it since then (Great product by the way!).
I followed a couple of guides (hardware) etc, everything is great!
I was wondering why all the examples and guides (that I've read) were not using the byte type to store pin references instead of int ?
Since memory efficiency is something important when programming in a limited ram environment (as the Uno is), and that byte goes 0 to 255, shouldn't it be preferred over int ? And shouldn't that be taught to beginners(myself included) so that they start with good practices/efficiency in mind?
Edit:
  Serial.println(sizeof(byte));
  Serial.println(sizeof(int));
void loop(){}
Int uses 2 bytes,(16bits) while a byte uses.... well, 1 byte(8bits). :blush:
Of course, this is not a big improvement as It will only (at most, on an official Uno with 16 pins) saves you 128 bits. (( 16 * 8 * 2 ) - ( 16 * 8 )),
but still, there must be some micro-controllers with less ram and more pins out there.
Anyway, thanks!
Yes, but int is easier to type. All the examples are very small, so they tend not to teach good habits.
What's a pin reference? A pin number?
In that case const is preferred as that takes no memory at all.
eg.
const byte LED_PIN = 13;
PaulS:
That make sense, tho I think a 'warning' might be useful, anyway, thank you.
Yup, I should have said a reference to a pin. (Prob not the correct term, but in French it makes sense.)
+1 for the const buddy, if the sketch does not need to change it at runtime.
In C reference is a technical term, being basically the address of a variable.
Yes, if you are tight on memory you would use byte or char (or int8_t or uint8_t)
instead of int where you could, and various other means to reduce memory
footprint, but that's not the first aim of a piece of example code.
Using #define's or const int's to name pin numbers shouldn't have storage overheads.
MarkT:
I know that my friend, my bad to have used reference to refer to something (a HW address in that case) ]:slight_smile:
Yup, got the point. I was just wondering why I haven't seen a tip on that anywhere.
benjaminf:
I've done some tips, one mentions that:
Unfortunately I can't force people to read them. :slight_smile:
