Use costum C++ program to control Arduino outputs
Hello,I have Windows surface RT (Tablet PC) and my idea is to connect Arduino to it via USB, using arduoino outputs control (using relay) various things. So the quoestion is,can I write C++ program which could have control over arduino outputs in real time? (Main goal is to send electronical signals via Arduino outputs to where I want using only my Tablet interface - the costum C++ program) Really hoping to get answer.
You need to write a program on the arduino that reads the USB via the serial port to control the outputs. It will be quick enough - certainly on a relay timescale - to appear to be real time.
You could send "A" to turn on relay 1, "B" to turn it off, "C" to turn on relay 2...
Thanks a lot man,it is the perfect solution! So how I understand, I need to write little program in Arduino to recognise signals from Tablet PC and send the needed singnal further (to the device i connected to Arduino output). And now I can create any C++ program which just sends signals to Arduino and it knows what to do with it!
That is basically it.
