I recently found some cheap monochrome lcd displays on Aliexpress, but they dont seem to be designed for use with arduino. Would there be any was to run them with arduino?
lots of displays from ali work on arduino, could be tricky but with the right library it’s fine. what did you buy and what are your requirements?
@lolman2001 you posted this in installation and troubleshooting. This is a section only for getting the Arduino system up and running, not about your project.
Therefore I have moved it to a more appropriate system.
So you expect us to know what display you found. How are we supposed to know if you don’t post a link to what you have seen.
The first answer to get them working every time, is to put the unit gently on the ground in the original anti-static bag, then stomp on it as hard as you can.
The bag will hopefully contain the fragments and loose bits.
Then buy another module which has documentation, and come back here when it arrives.
Are you getting the impression that you missed out something critically important? ![]()
Almost nothing is. Arduino is an experimental platform, it can and should run with almost anything that is pragmatically possible. When they tag it "Arduino" it's most often just because it will increase sales. Except for shields, they have a specific pins footprint.
To use a display for which there is not an Arduino specific library you need to determine if you have enough RAM to support a display buffer, compatibility with the display's protocol, enough pins to connect to the display, and the speed to deliver the data.
I'd suggest you start with displays that are well documented and already have Arduino libraries. Then work from there to understand how they work and eventually write your own library for them, before you attempt to do so with a display you know nothing about.
a good starting point would be to identify whether they are graphical, or character displays.
Character displays often use versions of the HD44780 chipset, for which there are numerous existing libraries.
The graphical ‘dot matrix’ displays also have libraries, but you need to know the controller chipset and pin out details.
...them here.
