use enum in const char[] declaration
Hello, I'm trying to use an enum value inside a const char[] declaration but without luck:
enum test { ME };
const char line[] PROGMEM = "enumvalue of me: " ME " it is";
I think it must be possible as at compiletime all sizes are known and the result is a fixed length constant.
What would be the correct syntax?
Regards,
PeterV
It looks to me like you are trying to concatenate a number with a string and to make things worse you are trying to do it within a variable declaration and add to the problem you are trying to put it in PROGMEM
Is that really likely to work ?
What problem are you trying to solve by doing this ?
UKHeliBob:
Yes, this is exactly true.
If this works it saves development and processor time. No need to concatenate strings at runtime. If there's an int to char[] preprocessor directive it would work. I'm a long time developer but not in C/C++, i'm learning. I need some enum values in javascript, this is how I can combine them in
How about something like this
enum {aValue, anotherValue};
char buffer[40];
  sprintf(buffer, "aValue is %d, anotherValue is %d", aValue, anotherValue);
  Serial.println(buffer);
Something like that is what i have and it works but I want to optimize the code. Thats why I ask if it would be possible. Looks to me that the preprocessor / compiler should be capable of doing these kind of things as all sizes / values are known. But if not, ok, I skip the idea.
