Use GPS and Transmittor at the same time
Hi Guys, It's my first time on the forum and I have a question about using a GPS and transmitter.
I am using the GPS - EM506 and for the transmitter I am using an APC220 and had a question about the code.
  while (gpsSerial.available() > 0)
    if (gps.encode(gpsSerial.read()))
      displayInfo();
As you can see the while loop to check gpsSerial.available() > 0 is running and can transmit the gps data. I also have a BMP280 hooked up and want to transmit that data as well. I was thinking of putting them in 2 different functions and calling the gps transmission and BMP280 transmission as well but as you can see the while loop will keep running and therefore I can't run the rest of the code. I am stuck can you guys please help me figure out how to run other functions which are not dependent on the while loop. Thank you
Which Arduino do you have?
I am using an arduino pro micro or rather a adafruit pro micro
No, it won't. The Arduino can empty the incoming serial buffer orders of magnitude faster than the GPS can fill it.
