Use instance in constructor
Hi all,
I'm trying to use an instance as an argument to create a new instance (through a constructor), however I can't get it to compile.
.ino file
#include "LedBoard.h"
... defines ...
Adafruit_NeoPixel board1 = Adafruit_NeoPixel(TOTAL_LED_BOARD, PIN_LED_BOARD, NEO_GRB + NEO_KHZ800);
LedBoard ledBoard1 = LedBoard(board1);
LedBoard.h
#ifndef LedBoard_h
#define LedBoard_h
#include <Arduino.h>
 * Led Board class header for generating texts on a 32x8 WS2812b led board
class LedBoard {
	public:
		LedBoard(Adafruit_NeoPixel board);
#endif
LedBoard.ccp
 * Constructor
void LedBoard::LedBoard(Adafruit_NeoPixel board) {
	_board = board;
This is the output error:
/var/folders/8p/b_5tx19j1bzbfhwt_f6yyq5r0000gn/T//cckHuour.ltrans0.ltrans.o: In function `global constructors keyed to 65535_0_led_board.ino.cpp.o.3163':
<artificial>:(.text.startup+0x2a4): undefined reference to `LedBoard::LedBoard(Adafruit_NeoPixel)'
/var/folders/8p/b_5tx19j1bzbfhwt_f6yyq5r0000gn/T//cckHuour.ltrans0.ltrans.o: In function `nextbyte20':
<artificial>:(.text.startup+0x8a2): undefined reference to `LedBoard::setF()'
I've tried including <Adafruit_NeoPixel.h> to the .ccp file or remove it from the .ino and/or header file, but doesn't make any difference. Also saw some previews where they include a reference class Adafruit_NeoPixel on top, but doesn't seems to be working either.
Can somebody give me an example how to do this in C++ (I'm more a PHP and Phyton person).
Thank you!
With kind regards,
Tim
Pass a pointer (or reference) to a Adafruit_NeoPixel object instead. Have a (private) member in your LedBoard class that's a pointer (or reference) to a Adafruit_NeoPixel object.
Three problems that jumped out, there could be more:
  1. .ccp is not a valid extension for C++ files, the Arduino IDE will not compile it. You need .cpp.
  2. You have to include the class definition in your .cpp file (#include "LedBoard.h").
  3. The constructor in your .cpp file cannot have "void" in front of it.
gfvalvo also has a good point, keeping a copy to the NeoPixel object seems like an unnecessary waste of memory, and will probably produce unexpected results. (I'm not even sure if the Adafruit_NeoPixel class is copyable.)
Pieter
PieterP:
Pieter
Even if it compiles as copyable I wouldn't take a chance on having more than one copy. It can be very confusing even if the copy constructor is implemented properly.
PieterP:
Pieter
Thanks Peter, that helped me a lot! Feel so stupid using .ccp instead of .cpp.
I think this is an assumption mistake of mine, as I'm trying to use the instance as a reference and not copy it. In PHP all objects/instances are copied as references, but as I can tell, that's not the case in C++.
What's the correct include syntax, should I use #include <Adafruit_NeoPixel.h> in both the .h and .cpp files?
I've used this for the constructor now, and it seems to compile fine, is this the correct syntax for using references?
 * Constructor
LedBoard::LedBoard(Adafruit_NeoPixel& board) {
    _board = board;
Edit: seems the forum doesn't like emoji's very much
faim:
No, if you're going to pass a reference (instead of a pointer), then '_board' must be declared as a reference member of the LedBoard class. And, it must be bound to the parameter 'board' using an Initializer List.
