I am trying to use the code below to write data to a serial port in Java, but I cannot get it to work. Even though I send a command, I get no response from the serial port.
package serialtalk;
import gnu.io.CommPortIdentifier;
import gnu.io.SerialPort;
import java.io.InputStream;
import java.io.OutputStream;
//import processing.app.Preferences;
public class Main
static InputStream input;
static OutputStream output;
public static void main(String[] args) throws Exception
//Preferences.init();
//System.out.println("Using port: " + Preferences.get("serial.port"));
CommPortIdentifier portId = CommPortIdentifier.getPortIdentifier("/dev/ttyS3");
SerialPort port = (SerialPort)portId.open("serial talk", 4000);
input = port.getInputStream();
output = port.getOutputStream();
//port.sets
port.setSerialPortParams(9600,
SerialPort.DATABITS_8,
SerialPort.STOPBITS_1,
SerialPort.PARITY_NONE);
port.setFlowControlMode(SerialPort.FLOWCONTROL_NONE);
//System.out.write(buf, off, len);
String sCommand = "O,0,2,0";
byte[] b = sCommand.getBytes();
output.write(b);
Thread.sleep(500);
sCommand = "O,0,0,0";
output.write(b);
Thread.sleep(500);
int i = 0;
while(i++ < 10000)
sCommand = "V";
output.write(b);
Thread.sleep(500);
while(input.available()>0)
System.out.print((char)(input.read()));
port.close();
