Use linear encoder Gefran with Arduino UNO to detect motorcycle suspension behaviour
Hello to all
I'm writing from Italy and i'm not a totally newbie in electronics, (maybe concept can be little bit old...) but i am almost totally new with Arduino programming.
I have a project that i would make, a check system for motorcycle suspension movement.
A quick system description could be:
  • The linear encoder mechanically connected to motorcycle front fork, send signal to Arduino board.
  • The board trasform signals in mm to read on a display.
  • Millimeters values storeable for later download on a PC.
For the moment i have:
A Gefran PC-M- 175 linear encoder (datasheet attached) bought at at cheap price.
An Arduino UNO R3 board.
Before enter deeply in search and study for a working scketch, i would like to know if i need some other components, as hardware, to begin my project.
Is there someone who can give some infos
Thanks to all, Luigi.
Gefran PC-M-.pdf (783,5 KB)
So basically the "encoder" seems to be a 5k potentiometer. Connect one end to Gnd, the other to 5v, slider to an analogue input and you should be in business.
You'll need a display (obviously) and a battery, but those components should be all you need to do this. I wouldn't recommend powering it from the motorcycle: power is probably really dirty.
Thank you Jhaine.
I noticed that in datasheet there's an advice:
It means: do not use the transducer as potentiometer
What would intented the maker?
Maybe don't use the transducer to control a device with input current (e.g. volume in an audio amplifier)?
Thank Luigi.
Hi cedarlake.
Yes, there's no problem using an external power, but you mean "dirty" the power coming from the motorcycle battery?
Thanks, Luigi.
No, it says dont use it as a variable resistor, a/k/a rheostat.
The power from the motorcycle battery itself is fine. It's the magneto/generator charging the battery that's the problem.
Yes Cedar.
It's true. But before battery there' always a regulator/rectifier.
Anway, i could take power supply from a dedicated battery; device that i would build can be used not necessarily in races but in free practice too, where 1 kilograms more don't affect so much the performance.
I'm a newbie and prefer proceeding step by step. For the moment i'm drawing the electrical scheme to have approvation comment on forum. I know that can be elementary, but " a drawing is better than hundred words to explain..."
:+1: Thank you
