I use the MEMS-Microphone SPH0641LU4H-1 for my application. The sensor output is an PDM-Signal (no PWM) and i want to use an arduino to read this signal in. During the same time i want to use the arduino to generate a clock signal (3.072MHz or higher) for this sensor. I want to use a computer to read out and save the sensor data. The way how i save those doesen't matter.
Can you tell wich type of arduino i can use for such an application?
Yes sorry, that first reply had me fooled, please ignore it.
Any Arduino should be able to cope as long as you have enough memory for what you want. ( You haven’t said what that is yet ). Just take your PDM signal and put it through a low pass filter before connecting it to a biased analogue input.
Generate the clock signal from one of the timers so it uses no overhead.
