Use mqtt to select mode for FastLED flashing
Hi all,
I am using a WemosD1 to control Led strip, the programming for FASTLed modes is complete and working. Now having issue of using MQTT to select the correct mode to operate my leds.
Note:
  • WIfi connection has been made
  • Connected to mqtt server
  • Led modes (scenes) 0 ~ 6 switching is done with “switch” function in the main loop.
  • Mqtt is not selecting the correct scenes. The selected scene is always says default.
#include <SPI.h>
#include <PubSubClient.h>
#include <ESP8266WiFi.h> // Include the Wi-Fi library
#include <FastLED.h>
#define DATA_PIN 0 // hardware Data pin
#define NUM_LEDS 150 // Total No. of LEDs
IPAddress server(10, 0, 0, xx); //MQTT broker IP Address
struct CRGB leds[NUM_LEDS];
int currentScene=0;
int previousScene=0;
int selectedScene=0;
const char* ssid = “xxxxxxxxx”;
const char* password = “xxxxxxxxx”;
void callback(char* topic, byte* payload, unsigned int length)
//================Print whatever received to serial Monitor =========
Serial.print(“Message arrived [”);
Serial.print(topic);
Serial.print("] ");
for (int i=0;i<length;i++)
Serial.print((char)payload*);*
  • Serial.println();*
    //=============== MQTT SUBSCRIBE================
    String strTopic = String((char*)topic);
  • if (strTopic == “cmnd/WemosD1/LEDscene”)*
  • if (((char)payload[0]) != previousScene)*
  • if(((char)payload[0]) == 1)*
  • selectedScene = 1;*
  • Serial.println(“Scene Selection = 1”);*
  • else if (((char)payload[0]) == 2)*
  • selectedScene = 2;*
  • Serial.println(“Scene Selection = 2”);*
  • else if (((char)payload[0]) == 3)*
  • selectedScene = 3;*
  • Serial.println(“Scene Selection = 3”);*
  • else if (((char)payload[0]) == 4)*
  • selectedScene = 4;*
  • Serial.println(“Scene Selection = 4”);*
  • else if (((char)payload[0]) == 5)*
  • selectedScene = 5;*
  • Serial.println(“Scene Selection = 5”);*
  • else*
  • selectedScene = 0;*
  • Serial.println(“Scene Selection = Default”);*
  • previousScene = ((char)payload[0]);*
  • WiFiClient espClient;*
  • PubSubClient client(espClient);*
I think I know what’s the issue with the program, the mqtt message received is in ascii format (ie ascii 1 = 49 decimal). Hence I have come up with a fix for the issue:
Anyone know how to convert ascii message to decimal in a proper way?
I am having some slight delays sometimes in receiving mqtt messages on my Wemo, could that be the program?
Modified code below:
#include <SPI.h>
IPAddress server(10, 0, 0, 12);    //MQTT broker IP Address
int currentScene=0;
const char* ssid     = "xxxxxxxx";
const char* password = "xxxxxxxxxx";
  Serial.print("Message arrived [");
  Serial.print("] ");
  Serial.print((char)payload[i]);
  if (strTopic == "cmnd/WemosD1/LEDscene")
    currentScene = ((char)payload[0])-48;      // Don't know how to receive the message in decimal format
  if (currentScene != previousScene)
   if(currentScene == 1)
      selectedScene = 1;
      Serial.println("Scene Selection = 1");
    else if (currentScene == 2)
      selectedScene = 2;
      Serial.println("Scene Selection = 2");
    else if (currentScene == 3)
      selectedScene = 3;
      Serial.println("Scene Selection = 3");
    else if (currentScene == 4)
      selectedScene = 4;
      Serial.println("Scene Selection = 4");
    else if (currentScene == 5)
      selectedScene = 5;
      Serial.println("Scene Selection = 5");
      selectedScene = 0;
      Serial.println("Scene Selection = Default");
      previousScene = currentScene;
