sir ,
please take a look at my code . In this code when key1 will be pressed ,to get Function A .
if (( kpd.key[i].stateChanged ) && (kpd.key[i].kchar == 1)) // --------------------------------------
switch (kpd.key[i].kstate) { // Report active key state : IDLE, PRESSED, HOLD, or RELEASED
case PRESSED:
Function A;
case HOLD:
// Do when Hold
case RELEASED:
// Do when Released
/* case IDLE:
// Do when IDLE */
Now , I will make a change related to a variable integer.
suppose i put (int MODE = 0;) Variable integer,
I want , to get "Function A" when key1 is pressed and (MODE = 0, or MODE = 3,or MODE = 5 )
if I want , to get "Function B" when key1 is pressed and (MODE = 1, or MODE = 2,or MODE = 4 )
HOW can i add key1 pressing with (MODE =0 and MODE =3 and MODE =5) ,in single line to get FunctionA
HOW can i add key1 pressing with (MODE =1 and MODE =2 and MODE =4) ,in single line to get FunctionB
i hope you understand . please solve this issue ?????
