I try to write in my own words what I have understood
once every 10 minutes = 600.000 milliseconds switch on power of radio-module
wait 300 milliseconds to let do the radio-module its boot-procedure
then read and send temperature-data
wait 200 milliseconds to make sure the nrf24-module has finished sending the data
wait 59,5 seconds until the next minute arrived and then repeat the above described procedure.
Is this a correct description of what you want?
This is a repeat always the same steps sequence.
Such things can be coded with a StateMachine
Your application is a nice example to explain how state-machines work
You can imagine a statemachine as a machine that has different modes of operation
in your case these operations are coded as constants used by the state-machine
You should use self-explaining names that describe SPOT-ON what the state is doing
const byte sm_wait_1minute = 0;
const byte sm_switchPowerOn = 1;
const byte sm_wait_300ms = 2;
const byte sm_ReadSendTemp = 3;
const byte sm_wait_200ms = 4;
const byte sm_switchPowerOff = 5;
The code below has 3 useful macros for serial debug-output
this makes visible what the code is doing. At first jump over the macros and start reading at function
void myReadSendTempStateMachine() {
This code uses a IMHO more intuitive non-blocking timing function than the delay without understanding standard-example of the IDE
// MACRO-START * MACRO-START * MACRO-START * MACRO-START * MACRO-START * MACRO-START *
https://forum.arduino.cc/t/comfortable-serial-debug-output-short-to-write-fixed-text-name-and-content-of-any-variable-code-example/888298
#define dbg(myFixedText, variableName) \
Serial.print( F(#myFixedText " " #variableName"=") ); \
Serial.println(variableName);
// usage: dbg("1:my fixed text",myVariable);
// myVariable can be any variable or expression that is defined in scope
#define dbgi(myFixedText, variableName,timeInterval) \
do { \
static unsigned long intervalStartTime; \
if ( millis() - intervalStartTime >= timeInterval ){ \
intervalStartTime = millis(); \
Serial.println(variableName); \
} while (false);
// usage: dbgi("2:my fixed text",myVariable,1000);
// third parameter is the time in milliseconds that must pass by until the next time a
// Serial.print is executed
// end of macros dbg and dbgi
// print only once when value has CHANGED
#define dbgc(myFixedText, variableName) \
do { \
static long lastState; \
if ( lastState != variableName ){ \
Serial.print( F(#myFixedText " " #variableName" changed from ") ); \
Serial.print(lastState); \
Serial.print( F(" to ") ); \
lastState = variableName; \
} while (false);
// MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END *
// the states for the state-machine
byte myState = sm_wait_1minute;
const unsigned long powerOnWaitTime = 300;
const unsigned long FinishSendingWaitTime = 200;
const unsigned long PausingTime = 10000; // increase to 600000 for 10 minutes
unsigned long Waiting60SecsTimer;
unsigned long Waiting_ms_Timer;
void myReadSendTemp() {
Serial.println("Read and send temperature");
void SwitchPowerOn() {
Serial.println("Switching Power on");
void SwitchPowerOff() {
Serial.println("Switching Power OFF");
dbgc("statechange",myState);
switch (myState) {
case sm_wait_1minute:
// only once every 2000 milliseconds print
dbgi("waiting ",millis() - Waiting60SecsTimer,2000);
if ( TimePeriodIsOver(Waiting60SecsTimer, PausingTime) ) {
Serial.println("next Time to read and send temp has come");
myState = sm_switchPowerOn;
break; // immidiately jump down to End-of-Switch
case sm_switchPowerOn:
// lines of code to switch power on
SwitchPowerOn();
Serial.println("start waiting");
Waiting_ms_Timer = millis();
myState = sm_wait_300ms;
case sm_wait_300ms:
// only once every 100 milliseconds print
dbgi("waiting",millis() - Waiting_ms_Timer,100);
if ( TimePeriodIsOver(Waiting_ms_Timer, powerOnWaitTime) ) {
Serial.println("waiting over");
myState = sm_ReadSendTemp;
case sm_ReadSendTemp:
// code to read and sedn temperatur
myReadSendTemp();
myState = sm_wait_200ms;
case sm_wait_200ms:
if ( TimePeriodIsOver(Waiting_ms_Timer, FinishSendingWaitTime) ) {
myState = sm_switchPowerOff;
case sm_switchPowerOff:
// code to switch power off
SwitchPowerOff();
Serial.println("initialise waiting for next sending");
Waiting60SecsTimer = millis();
} // End-of-Switch
void PrintFileNameDateTime() {
Serial.println( F("Code running comes from file ") );
Serial.println( F(__FILE__) );
Serial.print( F(" compiled ") );
Serial.print( F(__DATE__) );
Serial.print( F(" ") );
Serial.println( F(__TIME__) );
// easy to use helper-function for non-blocking timing
boolean TimePeriodIsOver (unsigned long &startOfPeriod, unsigned long TimePeriod) {
if ( currentMillis - startOfPeriod >= TimePeriod ) {
// more time than TimePeriod has elapsed since last time if-condition was true
startOfPeriod = currentMillis; // a new period starts right here so set new starttime
return true;
else return false; // actual TimePeriod is NOT yet over
unsigned long MyTestTimer = 0; // Timer-variables MUST be of type unsigned long
const byte OnBoard_LED = 13;
void BlinkHeartBeatLED(int IO_Pin, int BlinkPeriod) {
static unsigned long MyBlinkTimer;
pinMode(IO_Pin, OUTPUT);
if ( TimePeriodIsOver(MyBlinkTimer, BlinkPeriod) ) {
digitalWrite(IO_Pin, !digitalRead(IO_Pin) );
Serial.println("Setup-Start");
PrintFileNameDateTime();
BlinkHeartBeatLED(OnBoard_LED, 100);
myReadSendTempStateMachine();
The serial output looks like this
09:58:43.680 -> Setup-Start
09:58:43.680 -> Code running comes from file
09:58:43.680 -> F:\myData\Arduino\pilutz-StateMachine-001\pilutz-StateMachine-001.ino
09:58:43.680 -> compiled Dec 28 2022 09:58:37
09:58:45.679 -> "waiting " millis() - Waiting60SecsTimer=2000
09:58:47.668 -> "waiting " millis() - Waiting60SecsTimer=4000
09:58:49.650 -> "waiting " millis() - Waiting60SecsTimer=6000
09:58:51.671 -> "waiting " millis() - Waiting60SecsTimer=8000
09:58:53.679 -> "waiting " millis() - Waiting60SecsTimer=10000
09:58:53.679 ->
09:58:53.679 ->
09:58:53.679 -> next Time to read and send temp has come
09:58:53.679 -> "statechange" myState changed from 0 to 1
09:58:53.679 -> Switching Power on
09:58:53.679 ->
09:58:53.679 -> start waiting
09:58:53.679 -> "statechange" myState changed from 1 to 2
09:58:53.679 -> "waiting" millis() - Waiting_ms_Timer=6
09:58:53.784 -> "waiting" millis() - Waiting_ms_Timer=103
09:58:53.885 -> "waiting" millis() - Waiting_ms_Timer=203
09:58:53.988 -> waiting over
09:58:53.988 -> "statechange" myState changed from 2 to 3
09:58:53.988 -> Read and send temperature
09:58:53.988 ->
09:58:53.988 -> start waiting
09:58:53.988 -> "statechange" myState changed from 3 to 4
09:58:53.988 -> "waiting" millis() - Waiting_ms_Timer=6
09:58:54.091 -> "waiting" millis() - Waiting_ms_Timer=103
09:58:54.193 -> waiting over
09:58:54.193 -> "statechange" myState changed from 4 to 5
09:58:54.193 -> Switching Power OFF
09:58:54.193 ->
09:58:54.193 -> initialise waiting for next sending"statechange" myState changed from 5 to 0
09:58:55.676 -> "waiting " millis() - Waiting60SecsTimer=1484
09:58:57.648 -> "waiting " millis() - Waiting60SecsTimer=3484
09:58:59.654 -> "waiting " millis() - Waiting60SecsTimer=5484
09:59:01.662 -> "waiting " millis() - Waiting60SecsTimer=7484
09:59:03.635 -> "waiting " millis() - Waiting60SecsTimer=9484
09:59:04.188 ->
09:59:04.188 ->
09:59:04.188 -> next Time to read and send temp has come
09:59:04.188 -> "statechange" myState changed from 0 to 1
09:59:04.188 -> Switching Power on
best regards Stefan
