You cannot use Arduino libraries with the PIC. Further possible incompatibilities are the number of transmitted bits for the variable type (word size), and bit and byte order.
Samanu:
In my configuration, logically, if the 8 or 10 bits word ( position parameter) is generated by a PIC, communicated to the nRF24 transmeter interfacing with the nRF24 receiver and finally communicated to the UNO ( base on Atmel) , I don't understand why it should or may not work.
I think you are asking if one nRF24 controlled by a PIC can communicate with another nRF24 controlled by an Atmega and the answer to that is YES. The nRF24 has no idea what is controlling it.
However a complication can arise if you try to send complex binary data - for example a 4-byte float value. You need to ensure that both microprocessors use the same binary format or can convert from one format to the other.
...R
HI,
So, once more, the devil is in the details...
Same thing for the choice between a cable which can get tangled with all mechanical parts around the steering wheel or that module not so reliable with possible breakdown at the wrong moment !
I will make in a first step some breadboarding. As a minimum I hope to make some progress in the fabulous world of micros and associated Arduino systems …
Thanks a lot for your patience and understanding
