I have a few leds and i want to control them with a function, but the array doesn’t seems to arrive at the function.
Here’s my code
for (int i = 2; i < 8; i++) {
pinMode(i, OUTPUT);//setting pins to OUTPUT
int leds[] = {1,4,5,7};//make array
arrayLeds(leds);//turn all leds on in the array
void loop() {}//no loop today
int arrayLeds(int array[]) {
int size = sizeof(array) / sizeof(int);//get lenght of the array
for (int i = 0; i < size; i++) {
digitalWrite(array[i],HIGH); //loop through array to turn led on
The function doesn’t get the whole array by value. The function gets a pointer to the array. So inside this function, sizeof returns 2 which is the size of a pointer.
This is a common pitfall. There’s no way around it. If the array argument isn’t going to be a fixed size every time, then you’ll have to pass the size along as another argument.
int arrayLeds(int array[], int size) {
Delta_G:
The function doesn't get the whole array by value. The function gets a pointer to the array. So inside this function, sizeof returns 2 which is the size of a pointer.
I missed that. I would have thought that sizeof(x) where x is an array type of unknown size should have generated a compilation error. sizeof() should be using the lvalue, not the rvalue.
PaulMurrayCbr:
In this case, x is a pointer to int, not an array of unknown size. sizeof (int *) == sizeof x, and on Arduino that is 2.
PaulMurrayCbr:
If you look at the generated code, you will see that what it does is perfectly logical. The argument the function actually receives is a pointer, NOT an array. So, sizeof returns the size of the argument, which is the size of a pointer. This is by design, and how c has always been defined c since it was first introduced in the '70s. Were it not so, a huge amount of time, and RAM, would be wasted copying whole arrays to the stack on function calls.
