Use Piezo Sensor as digital input
I am working on a project where I would like to use a piezo sensor (like Piezo Vibration Sensor - Small Vertical - SEN-09199 - SparkFun Electronics) as input.
While I could connect the sensor to an analog pin, I would rather connect it to a digital pin (as I only need a binary value).
The big question is....how would I go about that ?
The sensor can output a +/-90V AC charge, and I suspect that I will need to scale that down to a 5V charge.
I am not especially strong when it comes to resistors etc. So any help is much appreciated.
You should stay with analog readings and 'digitize' in your software.
Converting to external digital would require some circuitry and lose flexibity such as easy threshold adjustment.
At the moment I am just trying different approaches, but I would eventually like to be able to read two sensors at the exact same time. I can accomplish this through portmanipulation, but that requires the signal to be digital.
