All you have to do is do an analogRead() of that pin to get a value between 0-1023 and then use the map() function to transform it into the minimum-maximum time delay you want.
/Users/lee/Desktop/Main_Code_PT2399_edit/Main_Code_PT2399_edit.ino: In function 'void loop()':
Main_Code_PT2399_edit:483:26: error: 'decreaseincrease' was not declared in this scope
if ((current_ms - decreaseincrease) * subdivisionfactor[arrayid] >= min_delay) // Stay above the minimum delay time
Main_Code_PT2399_edit:496:26: error: 'decreaseincrease' was not declared in this scope
if ((current_ms + decreaseincrease) * subdivisionfactor[arrayid] <= max_delay) // Stay under max_delay
/Users/lee/Desktop/Main_Code_PT2399_edit/Main_Code_PT2399_edit.ino: At global scope:
Main_Code_PT2399_edit:567:3: error: 'readingtapbutton' does not name a type
readingtapbutton = digitalRead(tapbuttonpin); // read the state of the button into a local variable
Main_Code_PT2399_edit:568:3: error: expected unqualified-id before 'if'
if (readingtapbutton != lasttapbuttonstate) // the following loop will only be done, if the button state has changed
Main_Code_PT2399_edit:572:3: error: expected unqualified-id before 'if'
if ((millis() - lastDebounceTime) > debounceDelay) // the following loop will only be done, if the last change of the button exceeds the debounce time (=is a button press, not noise)
Main_Code_PT2399_edit:603:3: error: 'lasttapbuttonstate' does not name a type
lasttapbuttonstate = readingtapbutton; // save the reading to determine whether the button state has changed next time
Main_Code_PT2399_edit:605:3: error: expected unqualified-id before 'if'
if (millis() - firsttapmillis > 1000) // if there is more than 1000 ms between two taps, delta measuremant resumes; it can be longer than max_delay due to subdivision...
Main_Code_PT2399_edit:611:3: error: 'blinkfreq' does not name a type
blinkfreq = current_ms; // current_ms_subdiv / subdivisionfactor[arrayid];
Main_Code_PT2399_edit:612:3: error: 'currentMillis' does not name a type
currentMillis = millis();
Main_Code_PT2399_edit:613:15: error: expected constructor, destructor, or type conversion before '(' token
digitalWrite(greenpin, currentgreen);
Main_Code_PT2399_edit:614:14: error: expected constructor, destructor, or type conversion before '(' token
analogWrite(redpin, currentred);
Main_Code_PT2399_edit:615:14: error: expected constructor, destructor, or type conversion before '(' token
analogWrite(bluepin, currentblue);
Main_Code_PT2399_edit:616:3: error: expected unqualified-id before 'if'
Multiple libraries were found for "SPI.h"
if (currentMillis - blinkfreq > lastblinktoggle)
Main_Code_PT2399_edit:622:3: error: expected unqualified-id before 'if'
if (currentMillis - lastblinktoggle > led_lit_time)
Main_Code_PT2399_edit:707:1: error: expected declaration before '}' token
Used: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI
Multiple libraries were found for "EEPROM.h"
Used: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/EEPROM
exit status 1
// Use an analog potentiometer as a selector switch
// Number of switch positions, and maximum analog voltage
const byte numberOfPositions = 7;
const uint16_t maxAnalog = 1024;
Serial.println(getSWpos());
int getSWpos() {
return map(analogRead(A5), 0, maxAnalog, 1, numberOfPositions+1);
//############### ROTARY ENCODER (DELAY TIME) ######################
int sensorValue = analogRead(A2); // i added this
float current_ms = sensorValue * (5.0 / 1023.0); // i added this
// n = digitalRead(encoder0PinA);
// if ((encoder0PinALast == HIGH) && (n == LOW)) {
if (analogRead(A2)) // i added this
// if (digitalRead(encoder0PinB) == HIGH)
current_ms = current_ms - decreaseincrease;
current_ms = min_delay / subdivisionfactor[arrayid]; // Set to min_delay, if the decrease would have exceeded the minimum delay
current_ms_subdiv = current_ms * subdivisionfactor[arrayid];
potchangerequired = HIGH;
current_ms = current_ms + decreaseincrease;
current_ms = max_delay / subdivisionfactor[arrayid]; // Set to max_delay, if the increase would have exceeded the maximum delay
encoder0PinALast = n;
Arduino: 1.8.10 (Mac OS X), Board: "Arduino Duemilanove or Diecimila, ATmega328P"
/Users/lee/Desktop/_160403_Main_Code_PT2399_Control/_160403_Main_Code_PT2399_Control.ino: In function 'void setup()':
_160403_Main_Code_PT2399_Control:186:3: error: 'setPwmFrequency' was not declared in this scope
setPwmFrequency(redpin, 1);
/Users/lee/Desktop/_160403_Main_Code_PT2399_Control/_160403_Main_Code_PT2399_Control.ino: In function 'void loop()':
_160403_Main_Code_PT2399_Control:406:13: error: 'digitalPotWrite' was not declared in this scope
digitalPotWrite(slaveDelayPin, digipot_value);
/Users/lee/Desktop/_160403_Main_Code_PT2399_Control/_160403_Main_Code_PT2399_Control.ino:406:13: note: suggested alternative: 'digitalWrite'
digitalWrite
_160403_Main_Code_PT2399_Control:465:11: error: 'print_settings' was not declared in this scope
print_settings();
/Users/lee/Desktop/_160403_Main_Code_PT2399_Control/_160403_Main_Code_PT2399_Control.ino:465:11: note: suggested alternative: 'presetpin'
print_settings();
presetpin
_160403_Main_Code_PT2399_Control:534:5: error: 'digitalPotWrite' was not declared in this scope
digitalPotWrite(slaveModPin, moddepth);
/Users/lee/Desktop/_160403_Main_Code_PT2399_Control/_160403_Main_Code_PT2399_Control.ino:534:5: note: suggested alternative: 'digitalWrite'
digitalWrite
_160403_Main_Code_PT2399_Control:639:9: error: 'digitalPotWrite' was not declared in this scope
digitalPotWrite(slaveDelayPin, digipot_value); //Write the value to MCP digital potentiometer
/Users/lee/Desktop/_160403_Main_Code_PT2399_Control/_160403_Main_Code_PT2399_Control.ino:639:9: note: suggested alternative: 'digitalWrite'
digitalWrite
/Users/lee/Desktop/_160403_Main_Code_PT2399_Control/_160403_Main_Code_PT2399_Control.ino: At global scope:
_160403_Main_Code_PT2399_Control:704:1: error: expected declaration before '}' token
} // END of LOOP()
exit status 1
option enabled in File -> Preferences.
I commented out everything I don't need, I made the changes to the ROTARY ENCODER (DELAY TIME)
but I get not declared in this scope errors
Arduino: 1.8.10 (Mac OS X), Board: "Arduino/Genuino Uno"
/Users/lee/Desktop/160428 Taprecise Code Package/Main_Code_PT2399_edit/Main_Code_PT2399_edit.ino: In function 'void loop()':
Main_Code_PT2399_edit:480:24: error: 'decreaseincrease' was not declared in this scope
Main_Code_PT2399_edit:493:24: error: 'decreaseincrease' was not declared in this scope
/Users/lee/Desktop/160428 Taprecise Code Package/Main_Code_PT2399_edit/Main_Code_PT2399_edit.ino: At global scope:
Main_Code_PT2399_edit:505:1: error: 'encoder0PinALast' does not name a type
Main_Code_PT2399_edit:564:1: error: 'readingtapbutton' does not name a type
Main_Code_PT2399_edit:565:1: error: expected unqualified-id before 'if'
Main_Code_PT2399_edit:569:1: error: expected unqualified-id before 'if'
Main_Code_PT2399_edit:600:1: error: 'lasttapbuttonstate' does not name a type
Main_Code_PT2399_edit:602:1: error: expected unqualified-id before 'if'
Main_Code_PT2399_edit:608:1: error: 'blinkfreq' does not name a type
Main_Code_PT2399_edit:609:1: error: 'currentMillis' does not name a type
Main_Code_PT2399_edit:610:13: error: expected constructor, destructor, or type conversion before '(' token
Main_Code_PT2399_edit:611:12: error: expected constructor, destructor, or type conversion before '(' token
Main_Code_PT2399_edit:612:12: error: expected constructor, destructor, or type conversion before '(' token
Main_Code_PT2399_edit:613:1: error: expected unqualified-id before 'if'
Main_Code_PT2399_edit:619:1: error: expected unqualified-id before 'if'
Main_Code_PT2399_edit:704:1: error: expected declaration before '}' token
exit status 1
You commented out the declaration of the variable decreaseincrease, but your code still uses it.
Apparently, you commended out everyting you didn't need plus a bit more.
Your parenthesis also appear to be off since a lot of your code is outside a function.
You can also comment out large blocks of code much easier doing this
exit status 1
Those errors relate to my other comment - your parenthesis are off. If you auto-format your code (Ctrl-T) you will see the closing '}' for loop followed by a bunch more code. This is wrong. That closing '} needs to be further down your code.
Stop trying to hack some code you found into doing what you want. Start over fresh ONLY putting in what you want and (( ONLY THE BITS YOU UNDERSTAND LEAVE OUT EVERYTHING ELSE. )). You can use the code you found that "almost works" as a guide. Then, what you will be working on will no longer be some dark mystery from anothers mind. It'll be in your thinking.
I might even start by laying it out in human.
I want to do this
then this
and if I see this I'll do.. a OR b
