Use Same Pin on Multiple Different Shields
Is this possible?
Some pins are designed for multiple use, like the SPI interface or the I2C/TWI interface. In most other cases you can't use the same pin for two different shields. Sometimes you have to use a breakout board instead of a shield so you have control over what pins the device uses.
michael-:
Is this possible?
Sure, often called "common ground".
