Use serial monitor while COM port is in use?
I am trying to send a stream of numbers to the Arduino from an application on the PC (Simulink). I am having much trouble interpreting the number with the arduino. I've tried integers and float.
For debugging purposes, how can I use the serial monitor for debugging while the COM port is in use by Simulink? I get an "in use" error from either Simulink or Arduino, depending on which application starts first.
Also, How can I use serial.read () to interpret a 16 bit signed integer being sent by the PC?
This is a restriction from the PC operating system, only allowing one application at a time to connect to a specific comm port.
The Arduino serial.read() function can only deal (read) with one byte per read statement. If sending multbyte variables from a PC then your sketch code must read them as a series of individual bytes and then reassemble them into a int or long or float or array variable, as the case my be.
Lefty
Thanks Lefty,
What is the process of assembling the two bytes (for an int) into an integer? is the array[] function necessary here?
This is the code I’m currently toying with
if (inbyte == '*') { // this means its the start of a number
             tsv = true; //
             startTime = millis(); // start time is now
             while (millis() - startTime < timeout && Serial.available() < 4) { // allow 4 at least bytes to fill the buffer
             for (int i=0; i<2; i++) {
               b[i] = Serial.read();
             angval = int(b); // read an integer
             if (tsv == true) {
               int angLED = (angval/90)*255; // prepare for the PWM signal
               // int angLEDpwm = abs(angLED); // absolute value for PWM LED // truncated?
               // check if the value looks write
               analogWrite(6,angLED); // debug
               blue.write(angval); // write servo?
               angval = 0; // reset?
               Serial.print(angLED);
               //delay(30);
Are we to guess how b is declared?
When there is a disagreement between the code and the comment, the code is always right. Except in this case, both are wrong. You can’t cast an array to an integer.
Don’t you know what the code is doing? What exactly is the blue object? Blue is an adjective, not a noun.
This time I included the whole code, see below.
The comments aren’t always up to date, especially when I’m trying stuff
b is a two byte array, how do I make an integer out of that array? do I need the array in the first place?
of course not :slight_smile: blue is a four letter word
// Control the small blue servo
// Brian Leach
// april 12 2011
// integer value from simulink. use the signed 16 bit integer from simulink with servo.write
#include <Servo.h>
Servo blue;
int ang; // create array to hold servo angle
int new_ang = 90;
int old_ang = 90;
byte b[2]; // byte array
blue.attach(5, 1025, 1975); // servoName.attach(pin, min, max)
Serial.begin(19200); // begin serial @ 19200 bits/sec
pinMode(8,OUTPUT); // debug lights. red no serial
pinMode(9,OUTPUT); // debug light green yea serial
pinMode(6,OUTPUT); // output 6 LED
//pinMode(5,OUTPUT); // output 5 servo
byte homey = 90;
blue.write(homey); // set servo to mid-point
delay(1000);;
Serial.flush(); // clear the serial buffer before reading new data
memset(b, ‘\0’, 2);
boolean tsv = false; // boolean to decide if the servo should be sent commands
int angval = 0; // integer value of angle in degrees
if (Serial.available() > 0) { // only loop the serial structure if its serialing
digitalWrite(8,LOW); // red off // light green if serial data, red if NO serial
digitalWrite(9,HIGH); // green on
char inbyte = ‘\0’; // null?
int timeout = 1000; // waits 1 second for a number
long startTime = millis(); // now is the start time
//delay(1); // try a delay
while (millis() - startTime < timeout && inbyte != ‘*’) { // this is the header character in the Simulink bloc. the loop waits for it
inbyte = Serial.read(); // change the inbyte to the waiting byte
if (inbyte == ‘*’) { // this means its the start of a number
tsv = true; //
while (millis() - startTime < timeout && Serial.available() < 3) { // allow 4 at least bytes to fill the buffer
b = Serial.read();
  • angval = int(b); // read an integer *
  • int new_ang = angval;*
  • if (old_ang != new_ang) { // if new angle equals old angle don’t write anything*
  • if (tsv == true) {*
_ int angLED = (angval/90)*255; // prepare for the PWM signal_
  • // int angLEDpwm = abs(angLED); // absolute value for PWM LED // truncated?*
  • // check if the value looks write*
  • analogWrite(6,angLED); // debug*
  • blue.write(angval); // write servo?*
  • old_ang = angval; // reset?*
  • Serial.print(angLED);*
  • //delay(.5);*
  • else {*
  • digitalWrite(8,HIGH); // red ON*
  • digitalWrite(9,LOW); // green OFF*
  • analogWrite(6,0); // servo lite OFF*
  • delayMicroseconds(30);*
[/quote]
Throw away random amounts of as-yet-unread data. Sounds good to me. NOT.
Look at the documentation for the millis() function. The return type is unsigned long, not long.
          while (millis() - startTime < timeout && inbyte != '*') {
All variables in a conditional (the value returned by millis(), startTime, and timeout) should be the same type. You have three different types (unsigned long, long, and int).
               b = Serial.read();
Wait for there to be at least 3 bytes, so we can read both of them. Wrong.
You already know that this is wrong.
int new_ang = 90;
Global and local values of the same name are rarely a good idea, especially when neither one is needed. The local variable is assigned the value in angval. Why not just use angval in the comparison that follows?
Why? Wait a little while before looping and waiting for more serial data to arrive. Not needed, and is contributing to your timing issues, as is the Serial.flush() call.
Thanks for the suggestions everyone. The solution to this problem can be seen at the page below.
http://arduino.cc/forum/index.php/topic,58460.15.html
I am still not clear on this process. Solved it for integers, but am still unsure about other data types
Brian
