struct Settings
int time;
int interval;
String date:
I know that i can created different objects for this struct.
My question. In my program i can select diffrent probes to measure my water. My plan is now, that i can select (via my nextion display) my prefered probe and that, depending of the selected probe, the intern settings will change and set.
Lets say i define 2 probe objects for the struct:
Settings probe1;
Settings probe2;
What would be the best way to switch between this to pointers? I am struggling how to initiate the correct pointer. Lets say i create a menu on my display where i can select "probe1" or "probe2".
Note that the String class is a special case. It uses indirect data access and cannot be stored in a structure in the usual way. I would recommend that you use some other data type, such as fixed length strings. If this is a calendar date, then you don’t need strings at all; you can use, for example, integers for the day, month and year.
i tried to create a small example to gain more understanding:
#include <Arduino.h>
#include "EasyNextionLibrary.h" // Include EasyNextionLibrary
EasyNex myNex(Serial2); // Create an object of EasyNex class with the name < myNex >
// Set as parameter the Hardware Serial you are going to use
int selectedProbe;
struct Settings{
char devinename;
int day;
int month;
int year;
int hour;
int minute;
int second;
int interval;
int brightness;
Settings probe1;
Settings probe2;
Settings *selected_settings_ptr;
Serial.begin(9600); //Bauderate for Serial monitor
myNex.begin(9600); //Bauderate for Nextion
switch( selectedProbe )
case 1: selected_settings_ptr = &probe1; break;
case 2: selected_settings_ptr = &probe2; break;
void loop(){
myNex.NextionListen(); //This function must be called repeatedly to response touch events
void trigger1(){
I dont know if thats correct what i did. How i understand it:
I createtd 2 objects of my struct. probe1 and probe2. I also created a pointer of type of my struct. So wht happens: deppening on selectedProbe (which i will choose on my Nextion), my pointer will point to the adress of the selected probe.
Whats unclear (if i am right): Lets say i selected "2" of my selectedProbe:
selected_settings_ptr.devicename is not the same as selected_settings_ptr.devicename, when i am picking selectedProbe=1?
thank you again.
This is what i have so far: I think it works. At least i can store into diffrent elemtns depening on
the global seletedProbe:
#include <Preferences.h>
#include <functions.h>
#include <globals.h>
int selectedProbe = 2;
struct Settings{
char devinename[15];
int day;
int month;
int year;
int hour;
int minute;
int second;
int interval;
int brightness;
Settings probes[7];
Preferences preferences;
preferences.begin("Settings"); //namespace
preferences.getBytes("Settings",&probes[selectedProbe],sizeof(probes[selectedProbe]));
Serial.print("****: ");
Serial.println(probes[selectedProbe].devinename);*/
void loop(){
void trigger1(){
String deviceName = myNex.readStr("t0.txt");
strcpy(probes[selectedProbe].devinename,deviceName.c_str());
preferences.putBytes("Settings", &probes[selectedProbe], sizeof(probes[selectedProbe]));
preferences.end(); //close namespace*/
As u can see, i expermiented a bit with prefrences. Since i wanna store the data of the different settings of each probe to use it later again, whats the best approach to save them here.
Is it possible to save each struct of probe into preferences. My research concluded that putBytes should be the way to go. but to fullfill my goal i have to set the name of the namespace form the prefrences also to be a variable. Are my thoughts right?
When i use it like above i would aways overwrite my settings, since i always use the namespace "Settings"
To get back the values of a single probe you would load the whole array then extract the required probe data from it using its array index
Another thought. It occurs to me that you could make the code more readable by using an enum to give the array levels in the probes array meaningful names. This would mean that you could have lines of code like this
if (probes[top].brightness > 123)
probes[top].interval = 1000;
