Use the unix Screen program to interact with Arduino via UART
I can use screen to Read values coming from Arduino just fine:
int n = 0;
while (1)
   Serial.println(n++);
And can see the output with screen /dev/cu.usbmodem14201 9600.
But I cannot write anything To Arduino, this code with Screen never prints anything. I press keys in Screen, RX led flashes on the Arduino board but nothing is printed back on my Screen.
int serIn;
while (1)
    if (Serial.available())  // <-- this is always -1
        while (Serial.available() > 0)
            serIn = Serial.read();
            Serial.print(serIn);
i’ve used the code recently to communicate to a serial interface on an arduino mega. i built it using cygwin on a Windows 10 laptop
// monitor NCE cab-bus
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <getopt.h>
#include <string.h>
#include <fcntl.h>
#include <unistd.h>
#include <pthread.h>
#include <termios.h>
#include <time.h>
#define DBG_TTY     1
#define RD_BUF_SIZE 32
char        *progname;
unsigned int debug = 0;
unsigned int flag  = 0;
int     addr        = 9;
int     speed       = B9600;
char    port [20]   = "ttyS4";
// open and configure RS-485
//    NCE cab-bus is 9600bps, 8 data bits, no parity, 2 stop bits
void
dispTty (
    struct termios  tty,
    char*           label )
    printf (" %s: %s\n", __func__, label);
    // check configuration
    printf (" %s: %08x c_iflag\n", __func__, tty.c_iflag);
    printf (" %s: %08x c_oflag\n", __func__, tty.c_oflag);
    printf (" %s: %08x c_cflag\n", __func__, tty.c_cflag);
    printf (" %s: %08x c_lflag\n", __func__, tty.c_lflag);
    printf (" %s: %08x c_cc [VMIN]\n",  __func__, tty.c_cc [VMIN]);
    printf (" %s: %08x c_cc [VTIME]\n", __func__, tty.c_cc [VTIME]);
    printf (" %s: %08x c_cc [VSTART]\n",  __func__, tty.c_cc [VSTART]);
    printf (" %s: %08x c_cc [VSTOP]\n",   __func__, tty.c_cc [VSTOP]);
 // printf (" %s: %8d  NCCS\n", __func__, NCCS);
    printf (" %s: %08x i speed\n", __func__, cfgetispeed (&tty) );
    printf (" %s: %08x o speed\n", __func__, cfgetospeed (&tty) );
    printf ("\n");
struct termios  ttyStdin;
void
restoreStdin ()
    if (0 != tcsetattr (0, TCSANOW, & ttyStdin))  {
        perror ("tcsetattr fault");
        exit (1);
void
reconfigStdin ()
    struct termios  tty;
    if (0 != tcgetattr (0, & tty))
        perror ("tcgetattr fault");
        exit (1);
    memcpy ((char *) & ttyStdin, (char *) & tty, sizeof (tty));
    // dispTty (tty, "stdin before");
    tty.c_lflag  = tty.c_cflag & ~ICANON;       // disable canonical
//  tty.c_lflag  = tty.c_cflag & ~ECHO;
    if (debug & DBG_TTY)
        dispTty (tty, "stdin");
    if (0 != tcsetattr (0, TCSANOW, & tty))  {
        exit (1);
int
openCfgRs485 (
    int     rd_size )
    struct termios  tty;
    char            dev [50]   = "/dev/";
    int             fd;
    strcat (dev, (const char*) port);
 // fd = open (dev, O_RDWR | O_NOCTTY | O_NDELAY);
    fd = open (dev, O_RDWR | O_NOCTTY           );
    if (0 > fd)
        perror (dev);
        exit (1);
    printf ("%s: opened %s\n", __func__, dev);
    // get configuration
    if (0 != tcgetattr (fd, &tty))
        exit (1);
    // dispTty (tty, "usb");
    // change configuration
    cfsetospeed (&tty, speed);
    cfsetispeed (&tty, speed);
    tty.c_lflag = 0;                                // no echo
    tty.c_oflag = 0;                                // no remapping/delays
    tty.c_cflag  = (tty.c_cflag & ~CSIZE) | CS8;    // 8 data bits
    tty.c_cflag  = (tty.c_cflag & ~PARENB);         // no parity
    tty.c_cflag |= CSTOPB;                          // 2 stop bits
#if 0
    tty.c_cc [VMIN]  = 4;     ;                     // read timeout
    tty.c_cc [VTIME] = 0;                           // read timeout
#else
    tty.c_cc [VMIN]  = 1;                           // read timeout
#endif
#undef  StartStop
#ifdef StartStop
    tty.c_cc [VSTART] = 0x88;                       // read timeout
    tty.c_cc [VSTOP]  = 0x80;                       // read timeout
    tty.c_iflag       = IXON;                       // enable start/stop
#else
    tty.c_iflag       = 0;                          // enable start/stop
#endif
    if (0 != tcsetattr (fd, TCSANOW, &tty))  {
        exit (1);
    return fd;
// display data in hex
void
disp (uint8_t *buf, int nbyte)
    int i;
    // printf ("%s: %d\n", __func__);
    for (i = 0; i < nbyte; i++)  {
        if ( ! (i % 16))
            printf ("\n  %4x: ", i);
        else if (! (i % 4))
            printf ("  ");
        printf (" %02x", buf [i]);
    printf ("\n");
// monitor
void *
monitor (
    void    *p)
    uint8_t     rdBuf [RD_BUF_SIZE];
    int         nread;
    int         n;
    int         fd      = (int) p;
    printf ("%s:\n", __func__);
    while (0 != (nread = read (fd, rdBuf, RD_BUF_SIZE)) )
        if (EOF == nread)
        for (n = 0; n < nread; n++)  {
            putchar (rdBuf [n]);
    printf ("%s: EOF\n", __func__);
    return NULL;
void
terminal ()  {
    pthread_t   tid;
    int         c;
    int         fd;
    fd      = openCfgRs485 (RD_BUF_SIZE);
    // keyboard icanonical
    reconfigStdin ();
    // create thread to monitor bus
    if (0 != pthread_create ( & tid, NULL, & monitor, (void*) fd))
        perror ("pthread_create");
        exit (1);
    // monitor keyboard for keypresses
    while (1)  {
        c = getchar ();
        if ('q' == c)  {
            restoreStdin ();
            return;
        write (fd, &c, 1);
    close (fd);
void
help (void)
    printf (" Usage: %s \n", progname);
int
main (
    int     argc,
    char  **argv )
    int     c;
    progname = *argv;
    while ((c = getopt(argc, argv, "D:s:p:")) != -1)  {
        switch (c)  {
        case 'D':
            debug = atoi (optarg);
        case 'p':
            strcpy (port, optarg);
        case 's':
            speed = atoi (optarg);
        default:
            printf ("Error: unknown option '%c'\n", optopt);
                        help();
    terminal ();
    return 0;
So that we can test your code, please provide complete sketches.
why not simply
loop ()
         Serial.print (Serial.read());
Serial.available() is always returning -1 for some reason.
Perhaps we could investigate that reason if you would post your entire sketch.
I use the simple “Minicom” terminal program on Linux Mint
apt-get install minicom, after install, minicom -s for setup.
