I've been searching hi and lo but could not find a proper solution. I bought 3 ATMega328P-PU with Arduino bootloader only to find out that I'd have to use an external quartz as a clock source.
I then followed the following tutorial to upload a bootloader that would make the ATMega use its internal clock: Gammon Forum : Electronics : Microprocessors : How to make an Arduino-compatible minimal board
The board detector tells me the ATMega is fine after burning the new bootloader.
I then uploaded the ArduinoISP sketch to the Uno, selected "Arduino as ISP" as programmer and "LilyPad Arduino w/ ATMega328" as the board and wired things up as described in the bottom left picture here: http://arduino.cc/en/Tutorial/ArduinoISP
When I try to upload the "Blink" sample I get varying error messages:
- Programmer not responding
- avrdude: stk500_getsync(): not in sync: resp=0x00
- avrdude: stk500_getsync(): not in sync: resp=0x1c
I've also tried to add a resistor between VCC and PIN 1 of the ATMega. I also tried to add a capacitor between RESET and GND on the Uno (as required to program ATTiny45s, which I've done successfully before).
What am I doing wrong? Is there some tutorial that I've missed so far?
ANY help is really appreciated.
PS: I've tried both 1.0.4 and 1.0.5+r2 of the Arduino environment.
