So I'm writing a program which sets a value to a string variable in the setup function. Next I try to use the value in a other function which is executed in setup and loop. The function is in another ino file.
My problem is that the value can't be accessed.
post the code using </>
is the variable defined globally or in setup()? needs to be global is used outside of setup()
The variable is defined gloablly. Do I need to import the global variable? Because I use multiple ino files?
Is it define globally in the sketch .ino file or in a .ino file on a tab ?
It is defined in the main ino file.
What is a MAIN INO FILE?
The one whose name is used when you save the sketch in a folder with the same name. It is the .ino file on the leftmost tab in the IDE
I assume that it is declared outside of a function, thus making it a global variable. It may, however, have its value defined within a function
Please post an example sketch showing the problem. It should be easy to show the problem in a minimal but complete sketch
Are we talking about a String variable or a string variable ? An example will tell use which it is
#include <HTTPClient.h>
#include <Arduino_JSON.h>
#include <WiFiManager.h>
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
int RXPin = 16; // Schaltplan schauen
int TXPin = 17;
int GPSBaud = 9600;
TinyGPSPlus gps;
SoftwareSerial gpsSerial(RXPin, TXPin);
// Zeitintervalle für jede Funktion aufstellen (Timer)
const unsigned long updateweather = 420000; // alle 7min wird die Temperatur laut OWM auf TFT gebracht; 10s für Testzwecke
unsigned long lastTimeweather = 0;
String lg;
String bg;
String jsonBuffer;
gpsSerial.begin(GPSBaud);
WiFi.mode(WIFI_STA); // WLAN-Verbindung aufbauen
WiFiManager wm;
bool res;
res = wm.autoConnect("Wetterstation", "WetterArmin"); // AP mit Passwort
if (!res) {
tft.setCursor(0, 50);
tft.print("Es konnte keine Verbindung aufgbeaut werden!");
else {
//if you get here you have connected to the WiFi
tft.setCursor(30, 75);
tft.print("Verbunden. Viel Spaß!");
delay(5000);
delay(5000);
while (gpsSerial.available() > 0)
if (gps.encode(gpsSerial.read()))
if (gps.location.isValid())
Serial.print("Breitengrad: ");
Serial.print(gps.location.lat());
Serial.println("Längengrad: ");
Serial.print(gps.location.lng());
Serial.println("Location: Not Available");
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println("No GPS detected");
while (true);
String bg = String(gps.location.lat());
String lg = String(gps.location.lng());
weathersetup();
// für Datenempfang von OpenWeather API
String httpGETRequest(const char* serverName) {
HTTPClient http;
// Your IP address with path or Domain name with URL path
http.begin(serverName);
// Send HTTP POST request
int httpResponseCode = http.GET();
String payload = "{}";
if (httpResponseCode > 0) {
//Serial.print("HTTP Response code: ");
//Serial.println(httpResponseCode);
payload = http.getString();
else {
Serial.print("Error code: ");
// Free resources
http.end();
return payload;
// tft_output
bool tft_output(int16_t x, int16_t y, uint16_t w, uint16_t h, uint16_t* bitmap)
if ( y >= tft.height() ) return 0;
tft.pushImage(x, y, w, h, bitmap);
return 1;
void wettersetup () {
// Check WiFi connection status
if (WiFi.status() == WL_CONNECTED) {
String serverPath = "http://api.openweathermap.org/data/2.5/onecall?lat=" + lg + "&lon=" + bg + "&exclude=alerts,hourly,minutely&appid=XXX&units=metric";
jsonBuffer = httpGETRequest(serverPath.c_str());
//Serial.println(jsonBuffer);
JSONVar myObject = JSON.parse(jsonBuffer);
// JSON.typeof(jsonVar) can be used to get the type of the var
if (JSON.typeof(myObject) == "undefined") {
Serial.println("Parsing input failed!");
return;
Serial.print(round(myObject["current"] ["temp"]));
I was hoping for a simple but complete example. As it is I have no idea which is the main .ino file, which is the subsidiary .ino file or which variable you are having a problem with
Here you are creating new local variables with the same name as your global variables. Your setup() function is setting the local variables! Try:
The first quoted code is the main ino file. The second code is one ino file. My problem is with the variables lg and bg.
See reply #11
