Use WifiManager on script
Hello guys, Are you fine? expect to be in the right session!
My trouble is: I uploaded a script found here on my ESP-01 to use it with alexa! But I don't want to be trapped with ssid and password inside the script...so I need to use WifiManager....I tried and suceed to find the device I named and get into the wifi login screen, but After that...My device is gone! My assigned name cant be found just a generic ESPXXXX random name...And Alexa cannot find the device... How can I put WifiManager inside this script without broken it?...
And How can I change the WifiManager SSID layout and messages?
Thanks in advance for your time!
Thats the original script...The one I edited I think I got frustrated and deleted it...But If you guys need to know What I tried I can try to remember and post here too...
#include <Arduino.h>
#if defined(ESP8266)
    #include <ESP8266WiFi.h>
#elif defined(ESP32)
    #include <WiFi.h>
#endif
#include <ESPAsyncWebServer.h>
#include "fauxmoESP.h"
// Rename the credentials.sample.h file to credentials.h and
// edit it according to your router configuration
#define WIFI_SSID "xxxxxxxxxx"
#define WIFI_PASS "xxxxxxxxx"
fauxmoESP fauxmo;
AsyncWebServer server(80);
#define SERIAL_BAUDRATE                 115200
//#define LED_BUILTIN                             2
// Wifi
void wifiSetup() {
    // Set WIFI module to STA mode
    WiFi.mode(WIFI_STA);
    // Connect
    Serial.printf("[WIFI] Connecting to %s ", WIFI_SSID);
    WiFi.begin(WIFI_SSID, WIFI_PASS);
    // Wait
        Serial.print(".");
        delay(100);
    // Connected!
    Serial.printf("[WIFI] STATION Mode, SSID: %s, IP address: %s\n", WiFi.SSID().c_str(), WiFi.localIP().toString().c_str());
void serverSetup() {
    // Custom entry point (not required by the library, here just as an example)
    server.on("/index.html", HTTP_GET, [](AsyncWebServerRequest *request){
        request->send(200, "text/plain", "Hello, world");
    // These two callbacks are required for gen1 and gen3 compatibility
    server.onRequestBody([](AsyncWebServerRequest *request, uint8_t *data, size_t len, size_t index, size_t total) {
        if (fauxmo.process(request->client(), request->method() == HTTP_GET, request->url(), String((char *)data))) return;
        // Handle any other body request here...
    server.onNotFound([](AsyncWebServerRequest *request) {
        String body = (request->hasParam("body", true)) ? request->getParam("body", true)->value() : String();
        if (fauxmo.process(request->client(), request->method() == HTTP_GET, request->url(), body)) return;
        // Handle not found request here...
    // Start the server
    server.begin();
    // Init serial port and clean garbage
    Serial.begin(SERIAL_BAUDRATE);
    // LED_BUILTIN
    pinMode(1, OUTPUT);
    digitalWrite(1, HIGH); // Our LED_BUILTIN has inverse logic (high for OFF, low for ON)
    // Wifi
    wifiSetup();
    // Web server
    serverSetup();
    // Set fauxmoESP to not create an internal TCP server and redirect requests to the server on the defined port
    // The TCP port must be 80 for gen3 devices (default is 1901)
    // This has to be done before the call to enable()
    fauxmo.createServer(false);
    fauxmo.setPort(80); // This is required for gen3 devices
    // You have to call enable(true) once you have a WiFi connection
    // You can enable or disable the library at any moment
    // Disabling it will prevent the devices from being discovered and switched
    fauxmo.enable(true);
    // You can use different ways to invoke alexa to modify the devices state:
    // "Alexa, turn kitchen on" ("kitchen" is the name of the first device below)
    // "Alexa, turn on kitchen"
    // "Alexa, set kitchen to fifty" (50 means 50% of brightness)
    // Add virtual devices
   // fauxmo.addDevice("kitchen");
  fauxmo.addDevice("luce");
    // You can add more devices
  //fauxmo.addDevice("light 3");
    //fauxmo.addDevice("light 4");
    //fauxmo.addDevice("light 5");
    //fauxmo.addDevice("light 6");
    //fauxmo.addDevice("light 7");
    //fauxmo.addDevice("light 8");
    fauxmo.onSetState([](unsigned char device_id, const char * device_name, bool state, unsigned char value) {
        // Callback when a command from Alexa is received.
        // You can use device_id or device_name to choose the element to perform an action onto (relay, LED_BUILTIN,...)
        // State is a boolean (ON/OFF) and value a number from 0 to 255 (if you say "set kitchen light to 50%" you will receive a 128 here).
        // Just remember not to delay too much here, this is a callback, exit as soon as possible.
        // If you have to do something more involved here set a flag and process it in your main loop.
        // if (0 == device_id) digitalWrite(RELAY1_PIN, state);
        // if (1 == device_id) digitalWrite(RELAY2_PIN, state);
        // if (2 == device_id) analogWrite(LED_BUILTIN1_PIN, value);
        Serial.printf("[MAIN] Device #%d (%s) state: %s value: %d\n", device_id, device_name, state ? "ON" : "OFF", value);
        // For the example we are turning the same LED_BUILTIN on and off regardless fo the device triggered or the value
      //  digitalWrite(LED_BUILTIN, !state); // we are nor-ing the state because our LED_BUILTIN has inverse logic.
       if (state==1) {
           // Serial.printf("accendo\n");
            digitalWrite(1, LOW);
                   delay(4000);
   else if (state==0) {
 //   Serial.printf("spengo");
            delay(2000);
    // fauxmoESP uses an async TCP server but a sync UDP server
    // Therefore, we have to manually poll for UDP packets
    fauxmo.handle();
    // This is a sample code to output free heap every 5 seconds
    // This is a cheap way to detect memory leaks
    static unsigned long last = millis();
    if (millis() - last > 5000) {
        last = millis();
        //Serial.printf("[MAIN] Free heap: %d bytes\n", ESP.getFreeHeap());
EDIT: I just realize I'm not in the right session...I swear I choose microcontrollers...If some moderator can Move please...
see the Basic.ino example of the WiFiManager library
Ok I found it. I'll try again! But I need the fauxmo for alexa interaction right?
