Useful RS232 chip
The Maxim DS275 Line-Powered RS-232 Transceiver Chip is an ultra low power RS232 interface that only requires +5V and tests out as ideal for the Arduino. It gets its -VE transmit by stealing it from the incoming RX - sneaky little trick :slight_smile:
(just like the two-transistor circuit in the original Arduino Serial, at several times the cost?)
... probably with the same reliability issues as the transistor trick.
-j
I can't actually see the point in this chip. First of all it is only designed as a half duplex device. That means you can't transmit and receive at the same time. Second if you need to supply +5V then you might as well have a 'real' chip like the max202 that generates the negative supply, that only needs +5V as well.
The main problem about passively powered RS232 devices is that you are stuffed if there is on on each end of your link. :wink:
The main problem about passively powered RS232 devices is that you are stuffed if there is on on each end of your link. Wink
Good point - that one never occurred to me :-[
