Useless Box Servo control
I am using a code off the net, I am trying to change the servo position for the finger / hand but dont understand the code. I have to remove some of the code for size reason.
Could someone explain the code for positions of the servo’s?
Thanks
#include <Servo.h>
Servo doorServo;
Servo fingerServo;
int swPin = 2;               //switch on pin 2
int pos = 0;               // 0
int selectedMove = 0;             //move selector
  pinMode(swPin, INPUT);
  doorServo.attach(9);           //set door servo on Pin 9 pwm
  fingerServo.attach(10);          //set finger servo on Pin 10 pwm
  doorServo.write(80);           //set door to hiding position 80
  fingerServo.write(80);            //set finger to hiding position  /0
void loop(){
  //if the switch is on, move door and finger to switch it off
  if(digitalRead(swPin) == HIGH)
    if (selectedMove > 9) {
    selectedMove = 0;
    } //when all moves are played, repeat the moves from beginning
    if (selectedMove == 0) {
    simpleClose();
    else if (selectedMove == 1) {
    simpleClose();
    else if (selectedMove == 2) {
    simpleClose2();
    else if (selectedMove == 3) {
    crazydoor();
    else if (selectedMove == 4) {
    slow();
    else if (selectedMove == 5) {
    serious();
    else if (selectedMove == 6) {
    trollClose();
    else if (selectedMove == 7) {
    simpleClose();
    else if (selectedMove == 8) {
    matrix();
    else if (selectedMove == 9) {
    sneak();
   selectedMove += 1;         //swith to next move
// Moves
   // basic move
   void simpleClose()
   //Moving door
    for(pos = 80; pos < 155; pos += 3)
    doorServo.write(pos);
    delay(15);
    //Moving hand
    for(pos = 80; pos < 129; pos += 4)  // 0 / 129 / 4
    fingerServo.write(pos);
    delay(15);
    //hiding hand
    for(pos = 129; pos>=0; pos-=4)      // 129 / 0 / 4
    delay(15);
    //hiding door
    for(pos = 155; pos>=80; pos-=3)
    delay(15);
   // open and wait, then move finger and wait, then switch off and hide
    void simpleClose2()
  //Moving door
    delay(15);
    delay(800);
    //Moving hand
    for(pos = 0; pos < 100; pos += 4)  // 0 / 100 / 4
    delay(15);
    for(pos = 100; pos < 129; pos += 4)  // 100 / 129 / 4
    delay(15);
    //hiding hand
    for(pos = 129; pos>=0; pos-=5)      // 129 / 0 / 5
    delay(15);
    //hiding door
    delay(15);
   //open door then close it many times, wait, then quickly reopen, switch off and hide.
   void crazydoor()
   //Moving door
    for(pos = 80; pos < 125; pos += 3)
    delay(15);
    //hiding door
    for(pos = 125; pos>=80; pos-=5)
    delay(15);
   //Moving door
    for(pos = 80; pos < 110; pos += 3)
    delay(15);
    //hiding door
    for(pos = 110; pos>=80; pos-=15)
    delay(15);
    delay(700);
   //Moving door
    delay(15);
    delay(700);
    //hiding door
    delay(15);
  //Moving door
    for(pos = 80; pos < 155; pos += 8)
    delay(15);
    //Moving hand
    for(pos = 0; pos < 129; pos += 3)  // 0 / 129 / 3
    delay(15);
    //hiding hand
    for(pos = 129; pos>=0; pos-=3)      // 129 / 0 / 3
    delay(15);
    //hiding door
    for(pos = 155; pos>=80; pos-=15)
    delay(15);
 //open door,move finger very slowly forward and back to hiding very slowly, then quickly close door
 void slow()
//Moving door
    for(pos = 80; pos < 155; pos += 1)
    delay(30);
    //Moving hand
    for(pos = 0; pos < 129; pos += 1)  // 0 / 129 / 1
    delay(30);
    //hiding hand
    for(pos = 129; pos>=0; pos-=1)      // 129 / 0 / 1
    delay(30);
    //hiding door
    for(pos = 155; pos>=125; pos-=1)
    delay(30);
    delay(100);
    for(pos = 125; pos>=80; pos-=4)
    delay(15);
Could someone explain the code for positions of the servo's?
The code to position the servos seems pretty straightforward. I can't understand what you need to know.
The choice of which servo to move, how move it, and where to move it to, are not at all obvious. That code assumes knowledge of the servo positions, orientations, and functions that are not apparent.
Perhaps reading about the Servo library will help you understand: https://www.arduino.cc/en/Reference/Servo
Reading about the 'for' loop should also help: https://www.arduino.cc/reference/en/language/structure/control-structure/for/
