User configuration file does not exist or is not a regular file, skipping?
Sketch uses 694 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
Programming with: Serial
Flashing with command:/Users/trent*****son/.arduino-create/arduino/avrdude/6.3.0-arduino17/bin/avrdude -C/Users/trentd****dson/.arduino-create/arduino/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodemFA141 -b115200 -D -Uflash:w:/var/folders/sf/5qf22b0s0kl7465t8cv29vjh0000gn/T/arduino-create-agent813424380/7_segment_display.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/trent*****on/.arduino-create/arduino/avrdude/6.3.0-arduino17/etc/avrdude.conf"
User configuration file is "/Users/tren****idson/.avrduderc"
Using Port : /dev/cu.usbmodemFA141
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
I do not think this has anything to do with my code. It is showing a file is missing for formated incorrectly. Not responding? Programmer is not responding? I have never had problems with the
compiler.
The warning in the title is harmless and can be ignored. It just tells you that you haven't created your own config (which most of us haven't).
It looks like you're using Arduino Create and I have no experience with it.
Please provide details; e.g. which board and which OS. Is the port /dev/cu.usbmodemFA141 indeed the correct port? Does it disappear when you disconnect.
@trent5233
Moved your topic to it's current location / section as it is more suitable.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
