I am trying to call my own functions within a case function but it comes up with the error that they are not declared within the scope.
The error that comes up flags the first function called so is therefore " ‘zeroPosition’ was not declared in this scope "
Is it possible to call the functions within a case or will I have to resort to another method?
Here is my code:
#include <AccelStepper.h>
#define STEPPER_X_TOP_DIR_PIN 10
#define STEPPER_X_TOP_STEP_PIN 9
#define STEPPER_X_BOTTOM_DIR_PIN 7
#define STEPPER_X_BOTTOM_STEP_PIN 6
#define STEPPER_Y_DIR_PIN 4
#define STEPPER_Y_STEP_PIN 3
#define step4Xtop 8
#define step4Xbot 5
#define step4Y 2
#define buttonPin 12
int buttonState;
int count = 0;
// Define some steppers and the pins the will use
AccelStepper stepperXtop (AccelStepper::DRIVER, STEPPER_X_TOP_STEP_PIN, STEPPER_X_TOP_DIR_PIN);
AccelStepper stepperXbot (AccelStepper::DRIVER, STEPPER_X_BOTTOM_STEP_PIN, STEPPER_X_BOTTOM_DIR_PIN);
AccelStepper stepperY (AccelStepper::DRIVER, STEPPER_Y_STEP_PIN, STEPPER_Y_DIR_PIN);
pinMode(buttonPin, INPUT);
pinMode(step4Xtop, OUTPUT);
pinMode(step4Xbot, OUTPUT);
pinMode(step4Y , OUTPUT);
digitalWrite(step4Xtop, HIGH);
digitalWrite(step4Xbot, HIGH);
digitalWrite(step4Y , HIGH);
stepperXtop.setMaxSpeed(2000);
stepperXtop.setAcceleration(1500);
stepperXbot.setMaxSpeed(2000);
stepperXbot.setAcceleration(1500);
stepperY.setMaxSpeed(2000);
stepperY.setAcceleration(1500);
// X-AXIS --- RIGHT IS NEGATIVE (-)
// X-AXIS --- LEFT IS POSITIVE (+)
// Y-AXIS --- UP IS POSITIVE (+)
// Y-AXIS --- DOWN IS NEGATIVE (-)
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState == HIGH) {
count++; // add 1 to the count
if (count > 3) {
count = 0;
else {
switch (count) {
case 1:
//do something when var equals 1
zeroPosition();
initiate();
case 2:
//do something when var equals 2
startPosition();
zeroPosition();
cleanFlatGlass();
YMoveDown();
cleanFlatGlass();
YMoveDown();
case 3:
YMoveDown();
cleanFlatGlass();
float distance (float mm)
float result;
result = 21.0526 * mm; // distance in millimetres
return result;
void zeroPosition ()
stepperXtop. setCurrentPosition(0);
stepperXbot. setCurrentPosition(0);
stepperY. setCurrentPosition(0);
void initiate ()
do
stepperXtop. moveTo(distance(-590));
stepperXbot. moveTo(distance(-590));
stepperY. moveTo(distance(272));
stepperXtop. run();
stepperXbot. run();
stepperY. run();
while ((stepperXtop.distanceToGo() != 0) ||
(stepperXbot.distanceToGo() != 0) ||
(stepperY. distanceToGo() != 0));
void startPosition () //this loop will be activated by a button press
do
stepperXtop. moveTo(distance(0));
stepperXbot. moveTo(distance(0));
stepperXtop. run();
stepperXbot. run();
void cleanFlatGlass ()
do
stepperXtop. moveTo(distance(-350));
stepperXbot. moveTo(distance(-350));
stepperXtop. run();
stepperXbot. run();
do
stepperXtop. run();
stepperXbot. run();
void YMoveDown ()
do
stepperY. moveTo(distance(-46));
stepperY. run();
while (stepperY.distanceToGo() != 0);
If it aids the understanding I am creating an automatic cleaner for a fish tank and each function is a set of movements for the stepper motors. I am really hoping that I can call the functions within the cases as it will massively simplify the main body of code.
Thanks,
Will
