Hi All,
Thank you for reading my post,
I have tied 2 Arduinos together with I2C and having a small problem.
Masters the one who will be running just the code (very fast <50ms per loop) and Slave will have some Temperature sensors and other stuff which will be relatively slow (about 1.2s per loop).
The main problem is that as soon as Master requests data from Slave, slave drops everything that is doing (the temperature measurement for instance).
What I would like is that Slave would do the measurement, indicate to a Master that data is ready to transfer and then Master requests and gets data. With that, I would avoid extra delay on the Master.
Is there a way or function that would help me with that problem (i am aware that it might not be possible)?
I have put together a test code where Slave on request sends 8 random numbers to a Master. Before sending they get translated to bytes and on the other end back to int.
Thanks,
MASTER:
#include <Wire.h>
#define SLAVE_ADDRESS 4
#define ANSWER_SIZE 16
int i = 0;
int sensors[8] = {0};
byte array_received[16];
Wire.begin();
Wire.requestFrom(SLAVE_ADDRESS,ANSWER_SIZE);
for(i = 0; i < 16; i++)
array_received[i] = Wire.read();
for(i = 0; i < 8; i++)
sensors[i] = array_received[i*2];
sensors[i] = (sensors[i] << 8) | array_received[(i*2)+1];
Serial.print(sensors[i]);
Serial.print(" ");
Serial.println("");
SLAVE:
#include <Wire.h>
int i = 0;
int sensors[8] = {2560, 2570, 1006, 2206, 310, 320, 2006, 2016};
byte array_send[16];
Wire.begin(SLAVE_ADDRESS);
Wire.onRequest(requestEvent);
delay(50);
void requestEvent()
array_send[i*2] = (sensors[i] >> 8) &0xFF;
array_send[(i*2)+1] = sensors[i] & 0xFF;
Wire.write(array_send[i]);
