Hello, i am Using the Pins 2,3,18,19,20 and 21 as Interrupt pins on an Arduino Mega 2560. I want to activate them in the Program when the Signal on the Pin is 0v, the Pins are currently connected to optocouplers that send a 5v signal to the Arduino when there is no Signal on the other End and 0v when there is a Signal. The Ground from the Arduino is connected to the Optocouplers. I tested the Program before just by connecting the Ground from the Arduino to the Pins and it worked but now when i connect it to the Optocouplers, they are sending points, even though there are 5 Volts connected to the interrupt pins. Can i set the Voltage for the Interrupt pins to Activate, for Example below 0,5 Volts. This is my Code below. Thank you for your answers
/* Settings Area */
/* Input Pins */
#define INI_PIN1 2
#define INI_PIN2 3
#define INI_PIN3 18
#define INI_PIN4 19
#define INI_PIN5 20
#define INI_PIN6 21
/* OUTPUT Pins */
#define RELAIS1 22
#define RELAIS2 23
#define RELAIS3 24
#define RELAIS4 25
#define RELAIS5 26
#define minWheelSpin 200
#define maxWheelSpin 2000
int Relais1Zeit = 0;
int Relais2Zeit = 0;
int Relais3Zeit = 0;
int Relais4Zeit = 0;
int Relais5Zeit = 0;
int GameStarted = 0;
#define BAUDRATE 500000
const int numPins = 6;
const int pins[numPins] = { 2, 3, 18, 19, 20, 21 };
const int Reifenpins[5] = { 22, 23, 24, 25, 26 };
const int points[numPins] = { 100, 50, 75, 100, 25, 0 };
bool pinStates[numPins] = { false };
int activeInis[numPins] = {};
int reifen0zeit = 0;
int reifen1zeit = 0;
int reifen2zeit = 0;
int reifen3zeit = 0;
int volatile IniStateISR = 0; // Changed inside ISR
struct RelayType {
int Output; // OUTPUT PIN
int State; // Current State ON / OFF
int IniState;
long CurrentTime; // How Long Relay is already on
long OnTime; // How Long the Relay should be on
RelayType REL1 = { RELAIS1,
0,
0,
0,
0 };
RelayType REL2 = { RELAIS2,
0,
0,
0,
0 };
RelayType REL3 = { RELAIS3,
0,
0,
0,
0 };
RelayType REL4 = { RELAIS4,
0,
0,
0,
0 };
RelayType REL5 = { RELAIS5,
0,
0,
0,
0 };
pinMode(REL1.Output, OUTPUT);
pinMode(REL2.Output, OUTPUT);
pinMode(REL3.Output, OUTPUT);
pinMode(REL4.Output, OUTPUT);
pinMode(REL5.Output, OUTPUT);
Serial.begin(BAUDRATE);
pinMode(INI_PIN1, INPUT_PULLUP);
pinMode(INI_PIN2, INPUT_PULLUP);
pinMode(INI_PIN3, INPUT_PULLUP);
pinMode(INI_PIN4, INPUT_PULLUP);
pinMode(INI_PIN5, INPUT_PULLUP);
pinMode(INI_PIN6, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(INI_PIN1), Ini1, RISING);
attachInterrupt(digitalPinToInterrupt(INI_PIN2), Ini2, RISING);
attachInterrupt(digitalPinToInterrupt(INI_PIN3), Ini3, RISING);
attachInterrupt(digitalPinToInterrupt(INI_PIN4), Ini4, RISING);
attachInterrupt(digitalPinToInterrupt(INI_PIN5), Ini5, RISING);
attachInterrupt(digitalPinToInterrupt(INI_PIN6), Ini6, FALLING);
void Ini1() {
IniStateISR = 1;
void Ini2() {
IniStateISR = 2;
void Ini3() {
IniStateISR = 3;
void Ini4() {
IniStateISR = 4;
void Ini5() {
IniStateISR = 5;
void Ini6() {
IniStateISR = 6;
void StartGame() {
if (Serial.available() > 0) {
//String lesen = Serial.readString();
//Serial.println(lesen);
if (Serial.readStringUntil('\n') == "GO") {
Serial.println("Spiel gestartet");
GameStarted = 1;
REL5.State = 1;
IniStateISR = 0;
void checkAndSendSignal() {
if (IniStateISR == 1) {
IniStateISR = 0;
Serial.println("50");
REL1.IniState = 1;
if (IniStateISR == 2) {
IniStateISR = 0;
Serial.println("100");
REL2.IniState = 1;
if (IniStateISR == 3) {
IniStateISR = 0;
Serial.println("250");
REL3.IniState = 1;
if (IniStateISR == 4) {
IniStateISR = 0;
Serial.println("500");
REL4.IniState = 1;
if (IniStateISR == 5) {
IniStateISR = 0;
Serial.println("1000");
if (IniStateISR == 6) {
IniStateISR = 0;
Serial.println("0");
REL1.State = 0;
REL2.State = 0;
REL3.State = 0;
REL4.State = 0;
REL5.State = 0;
GameStarted = 0;
void SetRandomTime() {
/* Set Random time if Ini is detected and Tire is not already spinning */
if (REL1.IniState == 1 && REL1.State == 0) {
REL1.OnTime = random(minWheelSpin, maxWheelSpin);
REL1.CurrentTime = millis();
REL1.IniState = 0; // Set to 1 to prevent endless spinning
REL1.State = 1; // Set to 1 if Tire spins
if (REL2.IniState == 1 && REL2.State == 0) {
REL2.OnTime = random(minWheelSpin, maxWheelSpin);
REL2.CurrentTime = millis();
REL2.IniState = 0; // Set to 1 to prevent endless spinning
REL2.State = 1; // Set to 1 if Tire spins
if (REL3.IniState == 1 && REL3.State == 0) {
REL3.OnTime = random(minWheelSpin, maxWheelSpin);
REL3.CurrentTime = millis();
REL3.IniState = 0; // Set to 1 to prevent endless spinning
REL3.State = 1; // Set to 1 if Tire spins
if (REL4.IniState == 1 && REL4.State == 0) {
REL4.OnTime = random(minWheelSpin, maxWheelSpin);
REL4.CurrentTime = millis();
REL4.IniState = 0; // Set to 1 to prevent endless spinning
REL4.State = 1; // Set to 1 if Tire spins
void spinRandomTire(int relayNumber) {
if (relayNumber == 1) {
if (REL1.IniState == 0 && REL1.State == 0) {
if (relayNumber == 2) {
if (REL2.IniState == 0 && REL2.State == 0) {
if (relayNumber == 3) {
if (REL3.IniState == 0 && REL3.State == 0) {
if (relayNumber == 4) {
if (REL4.IniState == 0 && REL4.State == 0) {
void CheckTime() {
if (millis() - REL1.CurrentTime >= REL1.OnTime) {
REL1.State = 0;
if (millis() - REL2.CurrentTime >= REL2.OnTime) {
REL2.State = 0;
if (millis() - REL3.CurrentTime >= REL3.OnTime) {
REL3.State = 0;
if (millis() - REL4.CurrentTime >= REL4.OnTime) {
REL4.State = 0;
void SetOutput() {
digitalWrite(REL1.Output, REL1.State);
digitalWrite(REL2.Output, REL2.State);
digitalWrite(REL3.Output, REL3.State);
digitalWrite(REL4.Output, REL4.State);
digitalWrite(REL5.Output, REL5.State);
StartGame();
if (GameStarted == 1) {
checkAndSendSignal();
SetRandomTime();
if (random(0, 30000) == 0) {
int pin = random(1, 4);
spinRandomTire(pin);
SetOutput();
CheckTime();
