Using 2 shields...
I'm using an Arduino Uno and need to attach two shields on it, (MP3 maker) and a DMX lighting one. I'm wondering if I need to worry about the ICSP pins when connecting them together. Also, I'm thinking these are the best option for attaching them:
http://www.amazon.com/100pcs-Stackable-Headers-extend-Solder/dp/B00AO0HRCU/ref=sr_1_2?ie=UTF8&qid=1429899354&sr=8-2&keywords=Arduino+Stackable+Header
Is that right?
Still new to all of this.
Mmm... those look like they may be the crappy kind - I see that critical review that clearly suggests that they are, and none of the 5 star reviews mention otherwise.
There are two kinds of stackable pinheader, which are very hard to tell apart before you order them, unfortunately.
Some of them have normal pins, as in, they fit dupont connectors, female header, etc. These are the ones you want.
Others are done cheaper, with a folded piece of thin metal, which is much thinner in one dimension than the other. As a consequence, it does not work reliably with all connectors. I have a commercial shield (from $parkfun, where else?) where I had to take a pair of pliers and twist the pins to get them to make reliable contact with the connectors I'm using.
As for ISP - it's only used for programming the Arduino. You can carry the ISP header through, but you don't have to, unless you plan to program it over ISP after attaching the shields. Just make sure you're not shorting pins together.
DrAzzy:
Not quite - on the Due the SPI pins are only available on the ISP header. I think future Arduinos could remove SPI from pins 10-13 and then all shields will be required to pass through these pins. You probably have an SPI LCD on top of the stack.
But if you don't need SPI on the top level you don't need to have these pins fitted to the shields underneath.
