Hardware:
Arduino Mini: https://www.sparkfun.com/products/11114
Accelerometer - ADXL 345: SparkFun Triple Axis Accelerometer Breakout - ADXL345 - SEN-09836 - SparkFun Electronics
Micro SD Breakout: MicroSD card breakout board+ : ID 254 : $7.50 : Adafruit Industries, Unique & fun DIY electronics and kits
I'm using SPI for both devices and have test code working for both separately but when i try to use them both, only the SD breakout works.
Wiring: Arduino Wiring | Micro SD Card Breakout Board Tutorial | Adafruit Learning System
CS - SD: 10
CD - ACCEL: 9
Code:
#include <SPI.h>
#include <SD.h>
const int chipSelectSD = 10;
const int chipSelectAC = 9;
File dataFile;
//This is a list of some of the registers available on the ADXL345.
//To learn more about these and the rest of the registers on the ADXL345, read the datasheet!
char POWER_CTL = 0x2D; //Power Control Register
char DATA_FORMAT = 0x31;
char DATAX0 = 0x32; //X-Axis Data 0
char DATAX1 = 0x33; //X-Axis Data 1
char DATAY0 = 0x34; //Y-Axis Data 0
char DATAY1 = 0x35; //Y-Axis Data 1
char DATAZ0 = 0x36; //Z-Axis Data 0
char DATAZ1 = 0x37; //Z-Axis Data 1
//This buffer will hold values read from the ADXL345 registers.
unsigned char values[10];
//These variables will be used to hold the x,y and z axis accelerometer values.
int x,y,z;
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(A3, INPUT);
pinMode(A4, INPUT);
pinMode(A5, INPUT);
pinMode(A6, INPUT);
pinMode(A7, INPUT);
pinMode(chipSelectSD, OUTPUT);
pinMode(chipSelectAC, OUTPUT);
SPI.begin();
//Configure the SPI connection for the ADXL345.
SPI.setDataMode(SPI_MODE3);
// set CS high for accel
digitalWrite(chipSelectAC, HIGH);
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelectSD)) {
Serial.println("Card failed, or not present");
// don't do anything more:
while (1) ;
Serial.println("card initialized.");
// Open up the file we're going to log to!
dataFile = SD.open("datalog.txt", FILE_WRITE);
if (! dataFile) {
Serial.println("error opening datalog.txt");
// Wait forever since we cant write data
while (1) ;
Serial.println("ACCEL INIT.");
//Put the ADXL345 into +/- 4G range by writing the value 0x01 to the DATA_FORMAT register.
writeRegister(DATA_FORMAT, 0x01);
//Put the ADXL345 into Measurement Mode by writing 0x08 to the POWER_CTL register.
writeRegister(POWER_CTL, 0x08); // Measurement mode
Serial.println("ACCEL INIT DONE");
// make a string for assembling the data to log:
String dataString = "";
// read three sensors and append to the string:
for (int analogPin = 0; analogPin < 8; analogPin++) {
int sensor = analogRead(analogPin);
Serial.print(sensor);
Serial.print(",");
dataString += String(sensor);
dataString += ",";
//Reading 6 bytes of data starting at register DATAX0 will retrieve the x,y and z acceleration values from the ADXL345.
//The results of the read operation will get stored to the values[] buffer.
readRegister(DATAX0, 6, values);
//The ADXL345 gives 10-bit acceleration values, but they are stored as bytes (8-bits). To get the full value, two bytes must be combined for each axis.
//The X value is stored in values[0] and values[1].
int x = ((int)values[1]<<8)|(int)values[0];
//The Y value is stored in values[2] and values[3].
int y = ((int)values[3]<<8)|(int)values[2];
//The Z value is stored in values[4] and values[5].
int z = ((int)values[5]<<8)|(int)values[4];
//Print the results to the terminal.
dataString += String(x);
dataString += ",";
Serial.print(x, DEC);
Serial.print(',');
dataString += ",";
Serial.print(y, DEC);
Serial.print(',');
Serial.println(z, DEC);
dataFile.println(dataString);
// print to the serial port too:
Serial.println(dataString);
// The following line will 'save' the file to the SD card after every
// line of data - this will use more power and slow down how much data
// you can read but it's safer!
// If you want to speed up the system, remove the call to flush() and it
// will save the file only every 512 bytes - every time a sector on the
// SD card is filled with data.
dataFile.flush();
// Take 1 measurement every 100 milliseconds
delay(100);
//This function will write a value to a register on the ADXL345.
//Parameters:
// char registerAddress - The register to write a value to
// char value - The value to be written to the specified register.
void writeRegister(char registerAddress, char value){
//Set Chip Select pin low to signal the beginning of an SPI packet.
digitalWrite(chipSelectAC, LOW);
//Transfer the register address over SPI.
SPI.transfer(registerAddress);
//Transfer the desired register value over SPI.
SPI.transfer(value);
//Set the Chip Select pin high to signal the end of an SPI packet.
//This function will read a certain number of registers starting from a specified address and store their values in a buffer.
//Parameters:
// char registerAddress - The register addresse to start the read sequence from.
// int numBytes - The number of registers that should be read.
// char * values - A pointer to a buffer where the results of the operation should be stored.
void readRegister(char registerAddress, int numBytes, unsigned char * values){
//Since we're performing a read operation, the most significant bit of the register address should be set.
char address = 0x80 | registerAddress;
//If we're doing a multi-byte read, bit 6 needs to be set as well.
if(numBytes > 1)address = address | 0x40;
//Set the Chip select pin low to start an SPI packet.
//Transfer the starting register address that needs to be read.
SPI.transfer(address);
//Continue to read registers until we've read the number specified, storing the results to the input buffer.
for(int i=0; i<numBytes; i++){
values[i] = SPI.transfer(0x00);
//Set the Chips Select pin high to end the SPI packet.
Thanks for the help!
