Using 2nd SPI Port with SD Library (ESP32)
Hello,
i have a project with an display and an sd card. Since both need an SPI Port i need to use the second Port for the SD card.
I use the ESP32 DevKit with 30 Pins.
bool EKG_recording::initialisation_sd() {
  SPIClass * hspi = new SPIClass(HSPI);
  if (!SD.begin(CS_Pin, *hspi))
    Serial.println("No valid SD Card!");
    return 0;
  else if (SD.begin(CS_Pin, *hspi))
    Serial.println("SD Card initalized");
    return 1;
  else return 0;
This part works. The SD Card gets detected no problem. But then when i try to call this function
unsigned short EKG_recording::count_files_from_SD(File dir) {
  dir.rewindDirectory();
  while (true)
    File entry = dir.openNextFile();
    while (entry.isDirectory()) { //check if open file is folder or not
      Serial.println("Still Directory");
      entry = dir.openNextFile();     //if folder open nextFile until file is found instead of folder
    Serial.println("This is counter:");
    Serial.println(counter);
    if (!entry)
      return counter;
    Serial.println("It counted Up");
    counter++;
    entry.close();
it just returns 0. I know for a fact that i have 3 files on this sd card. This means that entry = FALSE. But why?
Anybody has a clue what could be wrong? Before i used 2 SPI Ports this would actually work, so what has changed?
